700r4 tranny slipping!!
Car: 1992 Camaro RS
Engine: 305 TBI
i have a 1992 camaro rs and i just replaced the flywheel becuase the inner ring cracked and made a horrible winding sound the winding sound is back with the new flywheel on for about 3 motnhs flywheel has a tiny woople and the other night it wouldnt shift out of 3rd gearr(automatic) now sometimes when im crusing along it will slip like its in nutruel and kick hard into gear (any suggestions on what needs to be done ) cuz if i can avoid a rebuild i would love not
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Re: 700r4 tranny slipping!!
Did you replace the flywheel yourself or had a shop replace it? I am guessing that the TV cable was not reset when the transmission was installed. Try resetting the TV cable and hope your clutch is still holding. As far as the "winding sound is back" I would not drive the car any further until you can diagnose why this is happening. Are you or sure you torq the nuts to spec on the flywheel?
Car: 1992 Camaro RS
Engine: 305 TBI
yes reset the cable and yes tro torqed the nuts running threw the flywheel to the conveter... i also did the process myself i no its not the cable or the torq on the bolts cause it ran fine for about to months and the other night it wouldnt get out of third and its been acting fine no major sliping just a tinny lag and still a winding sound also today im dropn the pan and putting new filters and atf fluid in it to see if that stops the slip cuz i dont no the last itme it was changed (ur soposed to do it every 40000) so hopefuully that will fix the slip and ill see whats going on in there and ill probly reset the cable again to make shure thanks for you help tho
Car: 1991 RS Vert
Engine: LO3, 305, TBI
Having said that, I hate to be the old grumpy grammar ****, but please try to do some basic spell-checking and composition.
Seriously, I'm not trying to dog you for not using the King's English, but you make it very difficult to even determine what you are trying to say.
Well, that's not true. I can actually figure out what you are trying to say, I just choose to stop reading. So, it doesn't bother me, but on a site like this where you have come to receive help, you might be missing out on a lot of valuable input. Like mine.
(EDIT: If you just happen to be from another country, which I doubt due to some subtle clues in your writing, then you should put that in your post somewhere.)
TinnMann2
Canadian Region
16
06-18-2017 06:10 PM
[CA] 700R4 trans & parts
6998poncho
09-25-2015 03:56 PM
