700R4 will not shift 2-3 at WOT
It just started yesterday. I have to let off the gas for it to shift. A couple of months ago I put in a corvette servo and a .471 boost valve and it was shifting right. What could the problem be?
2-4 band,is about worn out.Time for a overhaul/buildup!Just had the samething happen to my car.
92 GTA(only 226 made)ort matched sportsman heads with 2.05 valves,64 cc,milled .015,.028 head gaskets,port matched Accel runners,port matched plenum,port matched edelbrock intake,flow matched injectors,jet hot headers and 2.5" mandrel bent exhaust,Flowmaster muffler,underdrive pulleys,slp cam,1.6 rockers,slp cold air induction,52mm throttlebody,performance resource custom chip,Dyna module,Screamin Demon coil,Accel 8.8 wires,Bosch platinum plugs,timing at 10 degrees,tb bypass,relocated map sensor,shift kit,Fairbanks billet servo,pump vane kit & 2400 stall,Torque converter lockup switch,3.42 posi with welded axle tubes,Zexel Torsen HD diff.,Summit rearend girdle,solid pinion spacer,& alloy axles.Boxed panhard bar,lakewood lca's & edelbrock strut tower brace,Jeg's torque arm,Jegs welded in subframe connecters.Performance friction pads,turbo slotted front rotors,stainless braid brake lines.Roh ZT 17x8.5 front wheels with 255/40ZR/17 tires. 17x9.5 rear wheels with 275/40ZR/17's on the street.Hoosier 26x9.5 slicks on the strip.
Get ready it is going to let GOOOOOO!!! That is what mine started doing, in fact it was doing it when I bought it but didn't know that it was a problem. The 2-4 band is about worn out. If you do the maintenance on it you can get another year out of it. I did and make sure you drive in D and not OD for your non freeway daily driving.
TPI 305,
Gutted airboxes,
gutted MAF,
K&N filters,
Corvette Servo.
14.9@93mph
"Speed kills, wanna live forever, drive a Ford."
TPI 305,
Gutted airboxes,
gutted MAF,
K&N filters,
Corvette Servo.
14.9@93mph
Ok so does i have a 92 RS...all gears work fine except for fourth. sucks having to drive on the highway only going 75mph. would that be the same thing?
92 25th anniversary
edition RS. 305 TBI
Straight stock but a
ram air hood and
flowmaster exhaust
"SUPER SLOW"
92 25th anniversary
edition RS. 305 TBI
ram air hood and
flowmaster exhaust
"SUPER SLOW"
Car: 1986 Firebird
Engine: 2.8 V6
Well, wait, I didn't have a 2-3 WOT upshift for 3 years, then the trans died- and it was related to a design flaw in the '86 700r4's- the pump starved for fluid.
Oops, just noticed Danny also has an '86.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
I will try something, I will add a little more fluid and see what will happen. A while back it had the same problem with the 1-2 shift at WOT and I found out it was low on fluid.
I talked to Dana at www.pro-built.net and he told me the 3-4 clutch pack is on its way out. So I will be saving some money for one of his stage 2 700R4 trannys.
I now have the same problem with my 86 700r4, it happened when I floored it in OD, I somehow managed to completly burn up drive It's been like this for about 2 months now and hasn't gotten any worse (or better), but I cant stand not being able to go over 75.... I changed the filter about 2 weeks about and it was nasty metal shavings everywere, so it looks like a rebuild is gonna be done pretty soon..... unless I can find a good t56 for around $700.....
86 TPI 305 Iroc-Z
Accel HEI Super Coil
Flowmaster
K&N Filters
Comp Cams High Energy 12-210-2
86 TPI 305 Iroc-Z
Flowmaster
K&N Filters
Car: 92 RS 25th Aniv. V8
Engine: 350 L05 TBI
Transmission: 700R4 Raptor
My 700r4 RAPTOR just came today, you might wanna just check this out, its a deal, and I will let ya know how I make out, Tomorrow night Ill be installing it, I cant wait! http://www.transmissioncenter.net/highperflist.htm
--G
92 RS 25th Aniv.
350 Goodwrench
--G
92 RS 25th Aniv.
350 Goodwrench
Zeek1041
Theoretical and Street Racing
09-30-2015 11:00 AM
TX-SleeperC5
09-24-2015 03:13 PM
