Clutch pedal feel
Clutch pedal feel
Ok I am a new thirdgen owner so I am not accustumed to it. I find that my clutch travels so far and that it only engages a little halfway up and finally bites about an a half an inch to an inch before I get to the the top of the travel. When do you clutches grip? How far up? Is this normal or is the clutch wearing. Thanks
1988 IROC-Z T-Top
350 Crate engine
370ft. lb Torque STOCK
5speed Centerforce clutch
1988 IROC-Z T-Top
350 Crate engine
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
Mine startes to grab right away try bleeding the clucth
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Mine grabs about half way. Most of the time i dont have to totally push the clutch all the way in to shift. Half way does it for me. Does anyone know if this hurts to car?
That is normal. Half way is good on a hydraulic clutch, on a cable (pre 84 cars) cluth half way is too little before grabbing because you run the risk of it having a constant slip. On a hydraulic cluth, it 'automatically' readjusts itself. Do NOT bleed it. Right now you have a 1:1 ratio, the ONLY way to reduce a 1:1 ratio in a hydraulic system is to add compression and the only way to add compression is to add air. This is not something that you want to do! You will not hurt your clutch/tranny if you don't push the pedal all the way down, aslong as you're not forcing it into gear or grinding your clutch is releasing fully and you're not putting overdue stress on the syncros.
1984 WS6 Trans Am Hartop
Former L69 Car under restoration
1984 WS6 Trans Am T-top car
4-bolt main 350, headers, Holley 650, T-5 and 3.23's.
Daily driver and restoration
camaro1185
10-26-2015 06:51 AM
Night rider327
09-02-2015 04:17 AM
