what is your 7004r crusing rpm?
Car: 85 camaro
Axle/Gears: 342
so i just switched from my turbo 350 to a built 700r4
im not positive of the rear gear ratio, but i was told it was 3.42 gears
my rear tire is a 235/60/r15, and with a tape measure it tiny bit under 26"
when im in od and the converters locked and at about 50mph, im turning 2000 rpm, is that right? it seems high to me, could the gears be 3.73 gears?
im just wanting other peoples setups and what kind of rpm they turn at what speeds, thanks guys
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: what is your 7004r crusing rpm?
That seems really high. When I am going 60 with my setup I am turning 1900 rpms
Car: 85 camaro
Axle/Gears: 342
what size tire are you running joe? see thats what makes me think that i have some weird gear, cause im so high in od with with converter locked, but maybe my tach is off too... im gonna get my buddies gps cause it tells you exact speed, and maybe figure something out after i test it like that... anyone else?
700r4, stock 3.27 rear gears. slightly higher stall than stock say 1800-2000. i cant get into overdrive until 55mph but im pullin 2000rpms at 60-65. it was lower like 1800-1900 but true dual exhaust 3" i lost alol low end tq.
urs is a bit high. i would say at least 3.42 but i would have thought 3.73 would be higher say like 2300 at 50mph... theres a formula for calcualtiong RPMs at a cruzing speed on here sumwhere....
Car: 85 camaro
Axle/Gears: 342
anyone else? im starting to think that my rear gears have to be something more like 4.10
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
255 50 16 tire 3.07:1 RG OD .7:1 TCC locked 70 mph 2000 rpm 58 mph 1700 rpm.
Car: 1979 Z28 / 1990 RS
Engine: Matching 350 / 305 TBI
Transmission: Built TH350, 3000 Stall / 700r4
ummm help me lol... at 55 mph im at just south of 3000 RPMS... Car runs great and no issues really but still. 3.23 rear gears, and P245/50/R16 tires. Someone please help me.
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
The numbers for my 3.07 RG, 255 50 16 tire, is 3000 rpm in 4th @ full stall is 56 mph, normal 4th lockup is 108 mph.
The only other thing would be 3rd and about 1/2 as much slip at 3000 rpm, my mph range is 40 to 75.
So with your lower gear and smaller tire, your mph should be just under my numbers.
Verify the rpm, some dash tachs read high with age.
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
@55mph w/ a 26" tire and 3.42 gearing i am running about 1850 RPMs.
custom built edge torque converter, painless TCC lockup harness.
never thought about that, thanks man.
Car: 1992 Camaro
Engine: 350 .030 over 298 cam 9.1 Flat tops
Transmission: T5 swap complete
Axle/Gears: 3.73 posi the 4.10s are history
I would think it is a converter problem, I have 4.10's in my 92 and at 70 mph I am running 2800 rpm and I top end at 90-100mph, not sure I still dont have my speedometer right. I know its about 30mph off when I was following a buddy on the interstate.
all my gears are being used. But i dont know. How hard is it to swap out a converter? Because i am not able to do that. I wouldn't know where to start. Would you have to take out the motor? -Matt
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
245/50/16
3.27 axle
75 mph = 2300 RPM
85 mph = 2500 RPM
100 mph = 3000 RPM
Try putting the car in 3rd gear and cruising at 70 mph. The tach should tell you what the axle ratio is. In my case, I rev at 3270 RPM.
3.27 axle
75 mph = 2300 RPM
85 mph = 2500 RPM
100 mph = 3000 RPM
mine is about the same as reid fleming... my converter is a few hundred more RPMs stall than stock but im at about 2000 at 60mph. 70mph is about 2300.
u have to drop the trans to swap converters. this isnt a big deal if u take it to a trans shop... they do it fast with a lift.
Damon
09-26-2015 04:29 PM
