8 inch 6k stall street driving ?
im swapping over to a th350 and transbrake behind my turbo v6 i was just gonna go with a 10inch 4k stall ,but i know someone with an 8inch 6k stall used that i can pick up pretty cheap.
i prolly wont get the 6k out of it maybe 5k,but on the transbrake who knows
can the 8inch converters hold up to street driving, i dont mean 10 mile trips to the store etc. im talking a 120 mile round trip down the shore once a weekend etc
i currently have the 700r4 with a 9.5 inch 4k stall and its never given me a problem just curious on the 8 inch converters though
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 8 inch 6k stall street driving ?
6000 stall isn't bad if the advertised duration of your camshaft is at least 324*. It still isn't very streetable. At low rpms, the converter will be slipping a lot and creating a huge amount of heat in the tranny oil.
268/272 adv its a v6 turbo car its rated for 6k behind a small block so im assuming id get 5k out of it behind the v6.
the cam i have should make peak power around 7k rpms but the problem is when driving around in non boost conditions the motor really dont make anykind of power maybe 200hp.
i figured go with the 8 inch cause its smaller and lighter then the 10 inch.
i want at minimum a 4k stall.
any suggestions?
any suggestions?
Hotrodboba400
12-10-2019 07:07 PM
roysatikas
09-22-2015 08:15 PM
