my tranny dipstick is leaking???
Okay guys i have just swapped a new 700r4 in with a new motor on my car.
My only issue is im leaking tranny fluid. At first it was the lines. I then fixed them.
Now it looks as if im leaking out of the dipstick. the dipstick is the original one from the old tranny.
Is there a seal or gasket i needed? or is it too overfilled if its leaking from there? Im really confused
I thought maybe the oil pan gasket, but the whole area where the dipstick goes in is oily
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: my tranny dipstick is leaking???
At the top of the dipstick tube, or at the bottom where it goes into the transmission?
Engine: 383 Carb
Transmission: 4L60
You need a new top hat seal. It probably got torn up putting the dipstick tube back in.
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
same thing happened to me. new packing fixed it. make sure your dipstick didn't get bent or anything while you had things apart and that its torqued down tight.
Engine: 383 Carb
Transmission: 4L60
It's between the dipstick tube and the transmission. You might be able to get one at a local parts store. They cost about $1.50.
Engine: 383 Carb
Transmission: 4L60
I can't think of which way I usually do it. I probably put it in the transmission first.
1 Post
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
really old thread.. when you out the seal in, do you just put it in or should you put some silicone on it or something?? REALLY novice questions i know, but id like to do it right the first time
tyeo098
11-30-2015 06:27 PM
