Hydrolic Clutch for T-10
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
I am building an 84 Z28. I am using it as my donor body for my 82. I have a Super T-10 and everything that goes w/ it. Everything was working when I pulled it out of the 82.
I went to mount up the Z bar from the Mechanical clutch, and the bolt holes were not there, and that is because the 84 had a hydraulic clutch in it.
Is it possible to get a T-10 bell housing w/ a hydraulic clutch for an 84 Camaro?? Or do I have to fabricate something to make my Z bar work for the mechanical one?? I would like to use the Hydraulic clutch, but whatever is easier/cheaper can also pull some weight.
What would be more cost effective. I have everything for both systems except for the bell housing for the hydraulic clutch.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Hydrolic Clutch for T-10
-You can drill holes in your frame and hook up the z-bar (less than ideal).
-You can buy a macleod bellhousing ($400), and put that on your T-10, then buy and use 1985 camaro clutch parts. ie the master and slave cylinders, etc.
-You can buy a hydraulic throw out bearing, and rig that up.
Pick your poison. Personally i've tossed my z-bar and am setting up a hydraulic TO bearing from Howe racing. Air_adam, another T-10 user here, has ditched his z-bar and is using the macleod BH. To each his own.
I already have the master and slave cylinders and such. I think I should buy the hydraulic throw out bearing and make that work. Is that all I would need. Would it mount to the 82 bell housing ok? 400 dollars is a bit steep for a bell housing, but if that is what I have to do that is what I will do.
Car: 1982 Trans-Am
If the hydraulic TO bearing is able to be set up with your existing master cylinder, then yes, you'll just need that.
It's a lot cheaper than buying that mega expensive BH, IMHO.
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If you look around a bit, you can get those bellhousings for reasonably cheap. I got mine for about $200. Just waiting for the clutch hydraulics to show up now.
Where did you find the Bell Housing, because I am thinking that the hydraulic clutch is not just going to bolt up...and I am putting over 400 ponies behind it soon. 200 bucks is within reason for something to bolt right up.
1 Post
That Lakewood scattershield is an 'explosion proof bellhousing' which is made of very heavy guage steel and is designed to contain the shrapnel of a clutch/flywheel coming apart. Thats most of the reason I got one, the hydraulic clutch provisions was just a huge bonus.
I actually found mine on the classified section of this board here, but I've also seen them on Ebay and other 3rdgen/4thgen websites as well (www.camaroz28.com has a MASSIVE classified section - mostly 4thgen, but lots of 3rdgen too).
