Will someone help me build my rear end!
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
Ok i have just the 2:73 right now not a posi. I want to keep the same rear end and make it a 3:73 posi. Can someone tell me how much it will cost and what will i have to do?
thanks
kevin
thanks
kevin
Car: 1987 Black IROC-Z (SOLD)
Re: Will someone help me build my rear end!
Old saying: If you have to ask the cost, you can not afford it.
The cost of Parts & labor (may vary with your location) $700/800 should be a ball park number.
If it isn't broke leave it alone.
Well i want to do it hear pretty quick as long as i can use my same rear end.
I just want to know all the parts i need then how much each part is. And yes i am a sophmore i high school but i have saved my last 4 pay cheaks and i have right around 800. But want to do as cheap as possible!
kevin
kevin
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
I just sold my rear end with 3.73 gears for 300
Get it back i'll give you $350 lol. So can anyone tell me just what i need to buy?
kevin
kevin
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
- Ring and pinion set
- 7.5" 10-bolt rebuild kit (all seals, shims, bearings, etc)
- Posi carrier (3 series) for either 26 or 28 spline axles (1990+ had 28 I beleive, yours could be either being a 1990)
- Gear oil and limitted slip additive (get the GM stuff, unless theres a mfg recommendation from whoever makes the posi you buy)
Ok so this is all that i need? Well thanks alot! Do you know a good place where i could buy it all? thanks for your help!
kevin
kevin
1 Post
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
air is right, except the cost of that carrier will be the same for a 3.73 rear end you could get out of a junkyard from the same car as yours which might need a low cost rebuild
1 Post
the carrier is the housing that has the actual gears inside... since the gears are different in size, the carrier is as well... usually a carrier with 2.08's for example can be upgraded to maybe a 2.73 or 3.08 but once you get to numerically "higher" gears such as 3.23's to 4.10's you need a bigger carrier to change the gears inside. so in this case, 3.73 gears cannot be put into a 2.73 carrier per say. and the fact its locking and you want posi... two different carriers all together.
Oh ok man thanks alot! Where could i buy one new? Also how much do they cost?
thanks
kevin
thanks
kevin
1 Post
AXLE HOUSING
CARRIER/POSI/DIFFERENTIAL
The carrier is not the axle housing, the carrier is the technical term for the posi unit/differential (the part the ring gear bolts onto). The carrier is different from 2.72 and 3.73 rear ends. The axle housing itself is the same for 2.73 and 3.73 rear ends.
AXLE HOUSING
AXLE HOUSING
Last edited by GoodlookinRS; 05-19-2008 at 06:10 PM. Reason: Automerged Doublepost
1 Post
i think i just re read my statement and i did say that "taller" gears wont fit into the original carrier... 'scuse my wording... only started working on cars when i was 9
1 Post
Anyway, back to Goodlookin's question.... Yes, a good quality, name brand posi unit is usually in the $400-500 range. Best place to look is Summit if you want a new unit.
Since this is going into a factory 10-bolt though, I would recommend checking Ebay or www.camaroz28.com or other 4thgen boards, and look for a Zexel/Torsen unit out of a '98+ Camaro for Firebird with the LS1. They are a very good unit, and since they are a clutchless design, they don't really wear out like a traditional Posi unit will. It would be considerably cheaper than buying a new $500 posi as well.
So will this make my car posi all the time is this going to do good for me?
Image is a representation of this part. Actual part may vary. Powertrax 1931-LR
$369.95
Estimated Ship Date: Today
Brand:PowertraxProduct Line:Powertrax Lock-Right LockersPart Type:Differential CarriersPart Number:PWT-1931-LRAftermarket Carrier Style:Gear-style lockerCover Bolts:10Axle Shaft Spline Quantity:28Manufacturer of Axle:GMCarrier Material:SteelQuantity:Sold individually.Differential, Lock-Right, Locker, 28-Spline, GM, 7.625 in., EachExtreme traction output.
The Powertrax Lock-Right and Performance Lockers' straight-line performance is equal to a solid spool axle, yet automatically unlocks to allow full differentiation in turns. The lockers also reduce the excessive noise, tire wear, and drivetrain damage associated with other lockers. Made in the U.S.A., Powertrax lockers replace the spider gears in your differential carrier without affecting your ring and pinion settings. The whole job can be done in your driveway with common hand tools in a couple of hours. A carrier is not included.
$369.95
Alright dude, I am in the process of rebuilding my 7.5 for an 86. Along with the ring and pinion and carrier you will need a pinion depth tool, a dial indicator and stand, and an installation kit. This kit has all the shims for setting up pinion depth and backlash as well as new bearings for the carrier and pinion, the pinion seal, crush sleeve, and ring gear bolts. These are left hand thread bolts so when you go to remove and reinstall, they don't follow the "lefty loosie, right tighty" rule. Do you have access to a press? Your going to have to use it for the pinion bearings and carrier bearings. Since your switching from a 2-series carrier to a 3-series, you'll most likely have to use a pinion depth tool in order to set that right. Otherwise you could just use the old shim from the old pinion. This link has some pictures and some pretty good info. Link
PM me if you need more...
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
This was the first thing that I ever did on a car. However, it takes a lot of time, money, and skill to swap gears, add posi, and set everything up. I went the easier route since I didn't have much mechanical knowledge at the time. I just found a complete rear end that had the posi & gears I wanted and bought that. It took about 2-3hrs the first time to remove the old rear end and install the new one. With your budget, you shouldn't need to spend more than half of what you have. Btw, I have done both methods and prefer to swap the whole rear end.
i just bought a 12 bolt completely built for $700. if you look hard enough you can find a rear end cheaply. however if you need parts i have a series 3 borg warner carrier with 3.73 gears for a ten bolt. will let it go cheaply, because i know what its like to have a small budget to work off of.
I just have the 10 bolt rear end.
kevin
kevin
GoodlookinRS I just have the 10 bolt rear end.
kevin
i was saying that i had a series three posi unit with 3.73 gears for a ten bolt up for grabs. you said that you were looking for a 3.73 gear and a posi unit for a ten bolt, and i have both. let me know if your interested
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
ok well in that case that 700 dollars u just spent was a waste....wow that sucks.
well unless u are either running a totally diferent rear end suspension set up, or its been modified to work in an third gen fbody...i.e. TORQUE ARM MOUNT, and set up for coils springs or coil overs....ive only seen that done like once or twice and i just dont know how strong that torque arem mount really could be....
Last edited by igotta355z28; 05-25-2008 at 08:42 PM. Reason: Automerged Doublepost
Heck ya man how much do you want?
Are they in good shape, do they need to be replaced or anything?
Do have some pics?
thanks alot,
kevin
Do have some pics?
thanks alot,
kevin
built by bmr racing for thr f body car with torque arm mounts, + every other bracket needed to put into a third gen and be able to use my stock disk brakes, i am sorry for leaving that out
Kevin, i put the gears in the car and only put maybe 50 miles on the gears, before i spun a **** load of bearings, car hasn't moved in two years. so idk like 130 + shipping, and i will throw in the axels as well because i want to make sure that it will go together for you okay. depending on how far of a drive it is for you, if you want to take a road trip, i will give you the whole 10 bolt for the same price, that way you dont have to worry about seting it up. let me know
thanks
kevin
i blew up the motor, the rear end is fine, i am not sure how many splines a series 2 carrier is and that is why i would give you the axles with it so there is no confusion, and i think that if it isnt to far of a drive, picking up the whole rearend may be some thing you want to consider. all that you would have to do is mount your brakes, and put it into your car, saving you the headache of having to set the gears up, shimming every thing, check pinion depth and end play and all of the other **** that is a pain in the *** in setting up the rear end. however it is your choice.
Car: 85 Firebird
Engine: SBC 383/88BW
Transmission: Built 700R4
Axle/Gears: Moser 9in/3.55
Now if only we had more friendly people around like madhatter, keep up the good work man
Ok man i want it just let me show it to my dad and see what he thinks. Then i would want the whole thing but it's over a 5 hr drive so i wont proubly do that.
I will get back with you tonight!
thank
kevin
thank
kevin
Ok i talked to my dad and he said can we get some pics? Were not going to drive out their so what ever you can send that will help out that would be great! So 130 + what ever the shipping will be.
kevin
kevin
i take the rear apart this weekend and take alot of pictures and post them some time this weekend, probably sunday, i got a wake and funeral this week so not much time to do it, but i try my best to get them for you this weekend
Hey man take your time no rush. Thanks alot though!
kevin
kevin
Hey man just checking back to see if your gonna have any pics soon.
thanks
kevin
thanks
kevin
i will have them up before the weekend i promise, ive been running circles all week between school and and my grandpas funeral, but i will get to it this week
Sounds good man by the way how much hp are you pushing out with you 357?
thanks
kevin
thanks
kevin
not sure, should be in the 630 range at the fly wheel on a 175 shot
if i dont see a 10.50 or better than im not spraying enough motor should hold up to a 275 shot safely.
Wow thats awsome! So how do you like having around 450 hp? I wanted 400 at the rear sometime or another.
kevin
kevin
#44
and last view, if you notice the pictures are all views of the ring gear as i spun it around to show that all is well, no missing teeth, so let me know what you want to do
#45
Ya dude looks good let show my dad. He will most likely say ok so i'll take everything you want to send.lol. So if you want to find out the shipping fee that will be great.
thanks
kevin
thanks
kevin
#46
Ya my dad said it looked good he just wants to know what is all in included. Our zip code is 45068. Just tell me how you want to ship it.
thanks
kevin
thanks
kevin
#47
axles, c-clips, ring and pinion, carrier yoke, pinion nut
and any other internal part that i am forgeting, i will take every thing out of the housing and ship it, cuz it wont do me any good, i would recomend that you buy the master rebuild kit, its like 90 bucks or cheaper, that would give you all of the 10 bolt housing seals, and shims, it would also include new bearings for the pinion and carrier, i think they also come with a new pinion nut, and they also have a cover gasket. that way when you are ready to set it up you wont be looking for bearings and other mic. parts at the last minute. the bearings look pretty good, with minor wear marks, but if your going to set it up do it right and replace the bearings and seals. also get marking compound so that you can check the wear pattern and make sure that it is set up where it should be. ill check shipping prices tomorrow. it shouldn't be more than 20 or 30 bucks
hectre13
12-11-2023 08:14 AM
hectre13
08-26-2015 08:17 AM
AkDrifted
08-17-2015 07:45 PM
