gears from a 97 bravada/s-10/blazer
Car: 89 Formula
Engine: LB9 TPI
Axle/Gears: 3.73(coming soon)
theres a rear end at the shop thats just sitting there..its a 10 bolt with stock 3.73s...can i use that ring and pinion in my stock rear end?
i have a stock 10 bolt with 2.73s
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: gears from a 97 bravada/s-10/blazer
Gears yes, but they won't fit on your carrier. You have a 2 series carrier. The 3.73 will be in a 3 series carrier. Since you have a 92, you'll have 28 spline axles. You can swap the entire carrier over into your differential.
Car: 89 Formula
Engine: LB9 TPI
i was gunna put it in my 89 formula 10 bolt sry
does the 89 have 28 spline axels
can i swap the whole carrier still?
Car: 87 IROC L98
There's very few 89's with 28 spline axles. If they were a late in the production yard build they may have 28 spline. The only way to know is to pull the axles and count the splines. Yours will probably have 26 spline axles. That means if you swap the carrier, you'll need new axles. 90-92 third gens have 28 spline axles.
Car: 89 Formula
Engine: LB9 TPI
can i jus use the axles form the other rear end?
take the axles,gears,carrier
or the axles are to big?
Car: 87 IROC L98
The only axles that are the proper length for a third gen are from another third gen. You won't find any junkyard axles the same length as third gen axles.
UltRoadWarrior9
09-02-2015 08:24 PM
