4th gen rear end
Car: 89 Camaro IROC
Engine: 383 Stroker
Transmission: turbo 400
4th gen rear end
im looking into swapping a 4th gen rear end into my 89 iroc. it has a 383 stroker putting out around 500 horse. is the forth gen rear end any stronger than the stock third gen rear end and will it be able to handle this kind of horse power without breaking?
Car: 87 GTA
Re: 4th gen rear end
Yes it is stronger. As for WILL it break? Sure. Everything braeks. Just a matter of how much it takes to break things.
Chances are though, your tires will slip before the axle breaks, at 500hp. Launches are what breaks things, not overall power.
Car: 1987 Black IROC-Z (SOLD)
The 4th gen rear are the same 10-bolt design and are the same as the 3rd gen 10-bolts. No changes except some may have a different limited slip.. Also note: they are 4" wider overall in width then 3rd gen rears.
Car: 87 GTA
4th gens have bigger ring gears, better limited slip units...besides the width.
Car: 87 GTA
If the rears are the same, why do 3rd gen owners put 4th gen rears in? Because the 4th gens are stronger. If it was just the LS difference, we'd just swap the in.
Why don't the 4th gen owners put 3rd gen axles in, to fit wider wheels & tires? Because ours are weaker.
1 Post
Car: 92RS
Engine: 305= boat anchor
Axle/Gears: 4th gen 3.23
Every thread that I have read says, that the 4th rears are just as weak as the 3rd rears,I have a 4th rear on my car but the reason is,better brakes and also I got fairly cheap.
The reason is the 3rd gen rears are getting hard to find for one. Better brakes is another reason.
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
Also these axles are not much stronger then stock 3rd gen rears
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
4thegn rear ends are the same internally - only the axle and housing length is different, as well as the brake mounting brackets in some cases. The center section and its internals are the same. Some used a different posi, but thats it. They aren't any stronger than a 1990+ 28 spline 3rdgen rear end.
The only real benefit of installing an LT1/LS1 rear end is that it probably has less miles on it, and a better rear brake setup. Thats it.
Car: 1989 Camaro, 2008 600RR
Engine: 311
Transmission: T-10
Axle/Gears: 02 SS Rear with 3.23 Gears
I thought the the major difference is the third gen used 26 spline axles and the 4th gen used 28 spline axles. The 4th gen is a few inches wider but it will fit. I have a 02 SS rear in my 89. Just run a different offset wheel in the rear to accomidate the wider rear-end.
Car: 89 Camaro IROC
Engine: 383 Stroker
i appreciate all the responces but would you guys go for the forth gen rear end swap or not? and if not what is an affordable rear end that i can put in that will handle the power?
they have run shorter rears in a 4th gen before and i am willing to bet a thirdgen rear would work under a 4th gen car but would need some custom sized wheels to run it.. deep dish
later 4th gen rears are cheap, lower mileage and have better brakes than our 3rd gens, except the later PBR 10 bolts and 9 bolts. They ahve the same brakes as the 93-97 fbody rears
the 98 up has the good 12inch brakes, ls1 brakes they are called
internals are about the same strength as the later model 3rd gen 10 bolts. There was a time where GM used 7.5" ring gears and went to the 7.625 so in that sense that extra 1/8 inch may make it stronger but its still a weak rear end. you can beef them up but they still weak. Also the axle splines were updated from 26 i believe to a 28 in the later years starting around 90 i believe but i could be wrong. all 4th gens tho have the higher splined axles. So if you have a drum or wimpy disk old 10 bolt, you can easily swap in a 4th gen low mileage throw out for 300 bucks or cheaper. much cheaper than upgrading your current posi, brakes and axles
later 98 up cars also got a torsen differential thats nice. different than auburn clutch type units that wear out.
but sticky tires and hard launches will hurt these rears... its only a matter of time. My buddy ran a stout 406 on his auto car 10 bolt rear just fine for 3 years. then went to a stick shift and still ran fine. only eventually broke but thats a stout piece to last that many years behind a 10 second motor
i plan to run my 500 hp 383 on my 4th gen 10 bolt till it breaks or i have enough money for a 12 bolt, which ever comes first
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
While they are both 10 bolt covers, that's where the similarity ends.
To the original poster: With that power I wouldn't waste my time putting in another 10 bolt that isn't going to be any stronger. You could spend a grand beefing it up but even then you still have a weak base and you're almost half way to a bullet proof rear end which you may end up needing anyway when you break your "beefed up" 10 bolt. Sure some people have taken 10 bolts low 11s, but a lot haven't. Risk you want to take spending money on a 10 bolt?
1 Post
Car: 1984 Z28
Transmission: TCI Streetfighter TH350
Axle/Gears: 4th gen 3.42
if the 4th gens have a higher spline count, thats means there are more contact points on the axle which means the amount of pressure per contact point is reduced so you have less of a chance of stripping the teeth on the axle, but thats really not a huge worry with these rears because there is plenty of other things that will break way before any of that happens
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
1 Post
Car: RS
Axle/Gears: 9" for the ladies
Good grief 4th gen rears have been covered a million times.
The 1st post should have been do a search lazy.
Instead we have 16 replies going in circles.
BTW Spline count is pretty irrevelant since that's not where a 10-bolt will first break.
Screw a 10-bolt. Mine broke years ago.
Get a 9-bolt for cheap and be done with it.
1 Post
Car: RS
I pull them out of the junkyard for $150 all day and bolt them up as-is.
Worst case is I have to replace a seized caliper or something.
Thinking you have to automatically rebuild it is a myth.
The current one in my car has been in it 6+ years AFTER coming out of a junkyarded mid 80's fbody and still never been touched internally other then new diff fluid.
That's 20+ years of use with no problems.
Did my friends 9-bolt the same way no problems.
Got a spare 9-bolt in my shed and know where I can go pull another 9-bolt out of the junkyard tomorrow if I want.
must be nice..i got a 3.27 ring and pinion and 3 series carrier used and threw it in my car, 1 year 6 months later it blew up
Hard to find a carrier around here or anywhere for that matter. Considering how few cars got the 9 bolt. Ppl on here charge an arm and a leg for good carriers... i said screw that for the same price i can get a like new 4th gen rear takeout. 30K miles, 3.42 gears, 12 inch disk brakes for 300
What cars will have the 9 bolt? How will I be able to distinguish the 9 bolt from the regular rear ends in the junkyard. Do you have to remove the backing plate or is there another way? One last thing, I have a 89 RS with the 2:78 single track. I found a 4th. gen with 3:23 posi. If I go with the 4th. gen. can I use my wheels? If not what backspacing do I need?
Car: 87 GTA
Identifying a 9-bolt is as simple as the name implies.....Look at the rearend cover...10 bolts = a 10-bolt rear, 9 bolts=a 9-bolt rear. Simple as that. But not all 9-bolts are created equal. If you get one, get a 89+. Before 89, they had smaller & "weaker" brakes.
And yes.....Despite some beliefs, you CAN use your stock rear wheels. They'll line up almost perfectly with the fender lip. Gives your car a nice, wide stance too.
Car: 85 Camaro
Engine: forged 383 11:1
Transmission: T56 TDP STAGE 2
Axle/Gears: 99 ws6 3.42 posi rear
I just had to mention how im selling a COMPLETE 9 bolt WITH brakes sway bar lca's and all 3.27 posi 9 bolt for 200 dollars with almot new rotors and pads...but NO ONE has even shown interest in it other than 1 guy. Funny when people are sayin everyones charging an arm and a leg.
Its obvious people just DONT use the search feature on this site for info or parts they just complain about crap and ask why over and over.
Car: 87 GTA
Nope. The 15" wheels won't clear the 98+ brakes. Good excuse to get 16" wheels, but even then, you might need to clearance the calipers, depending in the whee. Or just get 17"+!
Frigging Ricking Racking........
Thanks i've been trying to locate a posi disk rear all week and only came across one and it wont fit LOL
no room in the budget for new wheels just yet
hectre13
12-11-2023 08:14 AM
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
AkDrifted
08-17-2015 07:45 PM
