What speedo gear should I get for new 3.42?
1 Post
Car: 1987 IROC
Engine: 350 Gm H.O
Transmission: 700r4 built
Axle/Gears: 3.42 Locker
I have a 700r4 and 10 bolt rear that now has 3.42 gears from 2 series gears. My wheels are the stock p245 50r16 iroc rims Is it a hard job to change it and where is it? I also need to know what gear I should get and from who.
Thanks for the help
Thanks for the help
Re: What speedo gear should I get for new 3.42?
I'm pretty sure you can get the gears from summit. I copied this chart off of a post here on the web-site but I'll be damned if I remember which one...if you do a search on the site I"m sure you'll find more information. I hope this helps!
_____
3.08 has an 9-tooth drive gear (Pretty sure that's anything under 3.23.
3.23's up require a blue 7-tooth drive gear, plus the following driven
gear:
18 tooth (p/n 3987918) Brown = 3.23
19 tooth (p/n 3987919) White = 3.42
20 tooth (p/n 3987920) Blue = 3.45
21 tooth (p/n 3987921) Red = 3.73
22 tooth (p/n 3987922) Gray =3.77
_____
gear:
IROCZDAVE (88-L98)
11-19-2015 07:03 AM
dbrochard
09-19-2015 08:13 PM
UltRoadWarrior9
09-02-2015 08:24 PM
