No Reverse 700R4 Just Rebuilt
1 Post
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
Well I just rebuilt a 700r4 swaped it out with my current tranny. Put it in reverse... nothing its like its in nuetral.
Just as a note I did not touch the valve body.
All other gears work fine.
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Re: No Reverse 700R4 Just Rebuilt
You didn't actually ask a question here..
Anyway, the diagnosis lists 26 possible causes for this condition, apart for 5 things regarding the valve body, and the obvious linkage adjustment.
1 Post
Engine: L03, LS1
Well The internals looked fine. The shift cable adjustment is not it I can hear it click into reverse.
Obviously everything looked fine or you wouldn't have assembled it, would you?
Possible causes for no reverse or slipping:
Input Housing Assy:Oil Pump Assy:Reverse Input Clutch:Lo & Reverse Clutch:I left out the obvious worn plates and cracked drums which you wouldn't have put back in if they were.
Input Housing Assy:
- 3-4 Apply ring stuck in applied position.
- Forward clutch not releasing.
- Turbine shaft seals missing, cut or damaged.
- Retainer & ball assy missing or damaged.
- Stator shaft seal rings or grooves damaged.
- Stator shaft sleeve scored or damaged.
- Reverse boost valve stuck, damaged or misassembled.
- Cup plug missing.
- Restricted oil passage.
- Faces not flat.
- Converter clutch apply valve stuck.
- Cup plug missing.
- Faces not flat.
- Clutch plate retaining ring out of groove.
- Return spring assy retaining ring out of groove.
- Seals cut or damaged.
- Restricted apply passage.
- Porosity in piston.
- Belleville plate installed incorrectly.
- Excessive clutch plate travel.
- Clutch plate retaining ring mispositioned.
- Seals damaged.
- Return spring assy retaining ring mispositioned.
- Seals damaged.
1 Post
Engine: L03, LS1
Looks like you have the same books as me.
Haynes?
Haynes?
1 Post
Engine: L03, LS1
I rebuilt it haha.
Well its working now. Dont ask how I fixed it I just came down te next day and it worked. I am thinking fluid needed time to get in there?
Now I just have a wine when I am driving it.
A glass or two of red wine always helps, but you really shouldn't be drinkin & drivin u know! ![Wink](https://www.thirdgen.org/forums/images/smilies/wink.gif)
Just kidding..![Stick Out Tongue](https://www.thirdgen.org/forums/images/smilies/tongue.gif)
I don't think the fluid needs much time, maybe something was stuck. I wouldn't trust the tranny to last forever, so maybe better be prepared..
I quoted from a big GM Chevrolet Caprice & Monte Carlo Service Manual.
It has most everything except wiring diagrams..
Just kidding..
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 89 S10 Blazer
Engine: 355 tbi
Transmission: Built 700R4 w/ 2500 stall
Axle/Gears: 3:73 posi
You probably had a stuck valve. If you have a whine you obviously got a bearing or bushing whining or somthing, i wouldnt trust it for real long either.
![my 2 cents](https://www.thirdgen.org/forums/images/smilies/twocents.gif)
y dont u just tear it back apart...there is obviously something wrong.
it may be time costly and somewhat expensive but would you rather grenade your tranny, again...?
Car: 85 Z28 W/T-Tops
Engine: 383 crate engine edel carb n headrs
Transmission: ex700R4/NOW T5
Axle/Gears: 3.08 std
i say re-rebuild and in the process check all the points fullsizewagon mentioned. And yea you shouldn't be drinking and driving not a very smart thing to do
![lol](https://www.thirdgen.org/forums/images/smilies/lol.gif)
Hotrodboba400
12-10-2019 07:07 PM
GeneralIesrussi
09-03-2015 03:23 AM
