700R4 Dipstick tube
700R4 Dipstick tube
Im having a tough time getting the dipstick tube back in the trans after having it out and rebuilt. Trans is back in and in place, any suggestions. Go in from the top, the bottom? And it should bolt up where? Any constructive help would be thankful.
Car: 88 IROC
Engine: 5.0 tpi
Transmission: 700 r4
Re: 700R4 Dipstick tube
i leave the tube hanging against the back of the block when i stab the trans. when i get the trans flush to the block i install a couple bolts and then drop the filler tube into the trans. and the filler tube bracket lines up with one of the bell bolts. you may be able to drop the filler tube down from the top - good luck if you have a/c or headers. you may be able to drop the cross member and let the trans. hang and sneak it up that way.
no green
01-09-2016 09:22 PM
[CA] 700R4 trans & parts
6998poncho
09-25-2015 02:56 PM
