Lock up and brake switch
Car: 1986 Iroc
Engine: 305 TPI w/30,000 original miles
Transmission: 700r4 Transgo Shift Kit
Is there a way to put a toggle switch in the brake switch wiring? My converter locks up on the 1-2 shift and stays locked up. I want to put a toggle inline to trick the car in thinking that the brakes are applied. Mechanic said theres no pressure switches in the valve body. 1986 iroc 305 tpi
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Lock up and brake switch
turning on the brake light bulbs will in no way affect the trans
you cant use one of the manual lockup kits that allows you to control the lockup?
Car: 88 IROC
Engine: 5.0 tpi
Transmission: 700 r4
applying the brakes will disengage tcc lockup. there have been several posts made about this. if you can't find them i can help you out.
Car: 1986 Iroc
ive been trying to search the boards and i cant find anything clear cut could you help out?
Car: 88 IROC
Engine: 5.0 tpi
lock up should not occur in 1st or 2nd. if it is you have some other problem. be sure you have all the gears. lockup may occur in 3rd (depending on your setup) and in 4th. to test your lock up get a steady cruising speed and just touch the brakes. if the rpms drop a couple hundred then you had lock up. if you are getting lock up in 2nd i would try to fix the problem rather than fool the trans.
Car: 1986 Iroc
eh, 5 dollar switch or dropping the tranny pan again, which would you prefer? haha i just want it to kick out of lock up when im going up a hill, the shift kit did away with the half throttle 4-3 kickdown.
1 Post
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 10 bolt Richmond 3.73 posi w/ discs
You can order a kit from Bowtie Overdrives for $35 that will allow you to disengage the lockup when you hit the brakes
Car: 1990 Camaro RS
Engine: L03 305 TBI
Just for the sake of the knowledge, could someone explain to me whats going on here? Is Luthers car malfunctioning, or will this benefit him in some way? I would assume the TCC locking up (under hard acceleration) would be good. Is he just trying to stop if from locking up during normal acceleration? Is that the malfunction?
Hi All,
I have exactly the same problem on my 85 trans-am tranny , the LG4 engine is gone with it's ECM and now car is running with old school carb and I needed to wire the lock-up so found that thread , http://www.clubhotrod.com/forums/showthread.php?t=26644
and having still the lock-up wiring coming from the tranny , I've hooked the purple wire to the brake switch and put together the blue et and tan/black but tranny now locks in all gears... Even tried to ground the tan/black and purple to brake switch and still the same thing , any idea??
Thanks lot
Thanks lot
1992 Trans Am
05-10-2023 07:19 PM
