700R4 speedo gear Q:
Car: 92 Rs
Engine: 4 Bolt "010" 383
Transmission: 700R4 trans brake Hughes 3K convert
Axle/Gears: BW 9Bolt 3.70's
ive got a new tranny and i need to install the speedo gear onto the output shaft on the tranny. i dont know which hole the indexing clip goes into. can somone help please. there are two small round holes to choose from, im not sure its the one closer to the trans or closer to the end on the output. thanks
luke
luke
Car: 92 Rs
Re: 700R4 speedo gear Q:
did some searching and found how it goes. thanks anywho, clip goes in front hole, and with round side toward front as well.
luke
luke
IROCZDAVE (88-L98)
11-19-2015 07:03 AM
TheTraut88
09-07-2015 05:22 PM
370, 3k, 700r4, brake, converting, gear, gears, hole, install, output, shaft, speedmeter, speedo, speedometer, trans, transmission, witch
