I would like a posi for my 84 Z28
Car: 1986 Camaro
Engine: 350 v8
Axle/Gears: 10 bolt,disks, 3.23 posi rear
I would like to know what I should look for when I go to buy a traction aid
Re: I would like a posi for my 84 Z28
You'll need a 26 spline unit for an 84 rear. The Eaton, clutch style is your best bet if you can afford one. Stay away from the Eaton Gov-Loc and the Powertrax/Richmond No-Slip locker units. If you decide to buy used, get an Auburn 26 spline unit. Keep in mind they're not rebuildable though, so once it's shot, there's no fixing it. A Zexel-Torsen unit from a 98-02 f-body is an excellent choice for a used posi. They don't use clutches, so there's nothing to wear out. The only catch to using one of those is that you'll need a set of 28 spline axles from a 90-92 f-body. The Detroit Truetrac is similar to the Torsens(no clutches), and I think they make those in 26 spline units. They're cheaper to buy than the Eatons.
Car: 1986 Camaro
Engine: 350 v8
What about the axle out of this??? Along with the aluminum drive shaft, steering box and cat back exhaust, maybe even the rims,
http://boston.craigslist.org/bmw/pts/599665971.html
what about these springs?
http://boston.craigslist.org/gbs/pts/601989354.html
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
JamesC
Car: 1986 Camaro
Engine: 350 v8
If i go to buy it I will surely pull the cover to see if it is a posi
georgiaslim45
09-09-2015 08:12 PM
georgiaslim45
09-09-2015 08:11 PM
