ls1 driveshaft questions
Old 01-24-2008, 07:12 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
how many weights are on a ls1 driveshaft? I just got one and making sure everything is good before i install it. theres a sticker on the shaft with this number 12564004 is this the right one?
Old 01-24-2008, 07:58 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: ls1 driveshaft questions
Weights?? Depends if it needed balanced. I don't have the p/n but if it is a LSi 3" dia aluminum dr shaft there is only one the other is steel. Also it will fit any 3rd gen except some V6 cars.
Old 01-24-2008, 08:33 PM
1987_Z28's Avatar
Car: 1987 Z28
Engine: 355
If its used then it should already be balanced.
Old 01-25-2008, 12:01 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
yeah im just making sure all the weights are on there. theres one on there making sure there isnt suppose to be more
Old 01-25-2008, 12:33 PM
1987_Z28's Avatar
Car: 1987 Z28
Engine: 355
one way to find out is to put it in and c how it feels. Its not hard to swap a driveshaft it takes what 10 to 15 min and 4 bolts
Old 01-25-2008, 12:40 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If a weight is missing, you'll see where it was located on the d/s. My experience with JG1 shafts was that there was always one or two weights. Though I had 60+ of these in my possession at one time or another, I only remember a couple that had missing weights. If I were guessing (and I am), I'd say you were good to go.
JamesC
Old 01-26-2008, 12:43 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
anybody kno how to knock the u joints out of these driveshafts they have the plastic stick threw them the steel driveshafts i heat them to get the ujoints out not sure if i can do the same to aluminum
Old 01-26-2008, 08:09 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
they are too short for the early 200c and the 4 speeds. the t-5 and the 700r4 they will fit. v6 or v8 doesn't matter.
you use a torch to melt the plastic like you do the steel ones.
Old 06-26-2012, 02:38 PM
90redroc's Avatar
I have a 1990 IROC-Z with the 5.7 motor, 700r tran. and the 9 bolt borgwarner rear end. I have a aluminum drive shaft with a three rivers sticker on it with a part #12564004 will it fit my car?
Old 06-26-2012, 02:54 PM
90redroc's Avatar
I have a aluminum drive shaft part # 12564004 will it fit my 1990 IROC-Z?
Old 06-26-2012, 03:05 PM
JamesC's Avatar
Yes.
JamesC
Old 06-26-2012, 03:08 PM
90redroc's Avatar
Thanks!
Frozer!!!
01-19-2024 04:55 PM
sweet_87_iroc
09-25-2015 10:01 PM
redmaroz
08-16-2015 11:40 PM
reiderz iroc
08-13-2015 04:57 PM
Quick Reply: ls1 driveshaft questions
