700r4 acting funny....PLEASE HELP!
Old 01-18-2008, 07:04 PM
Imthebriman's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 350 TPI
Transmission: Brand New (again) 700r4
Axle/Gears: GM 10 bolt 7.625 W/ TrueTrac 3.23
Whenever I am messin around with the mustangs on the street, my tranny acts funny. At least that is what I think is doing it... When Im doing like 60 and I go to get on the gas to go the car starts to accelerate but then it starts up shifting then down shifting as it doesn't know what gear to be in. I am not sure if this is the transmission or maybe the torque converter(both were replaced at the same time). It doesn't do it during normal driving just when I am trying to race and it just gets annoying when they start pulling past me at the last minute because of my problem...
Old 01-18-2008, 09:21 PM
Re: 700r4 acting funny....PLEASE HELP!
anybody???
Old 01-19-2008, 08:06 AM
kanmudhog's Avatar
Car: 89 formula ws6
Engine: yes
Transmission: yes
Axle/Gears: both
The transmission and converter were replaced at the same time , how long ago ? was the transmission rebuilt or just a used one ? new converter or used one ?
Old 01-19-2008, 11:46 AM
Rebuilt transmission with a Monster Transmission Rebuild kit and a brand new stock converter about a little over a year ago.
Old 01-24-2008, 08:07 PM
Jimmy D's Avatar
Car: Camaros and Suburbans
Engine: V8's
Have you thought about the throttle cable secondary linkage? I should have read your post closer - don't know if you have a carb or F.I.
You could always use the process of elimination and try to manually shift through your gears. It shouldn't jump around on you. But...if it jumps around then it could be...???
O.K. guys, jump in here.
In the mean time, I'll keep thinking about this one.
Old 01-25-2008, 05:50 PM
hwcoll95's Avatar
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
sounds like TV cable,not new enuf to be electronic control,so its throttle pressure controled,heard of governors sticking causing similar prob
Fanatic1074
10-03-2022 05:57 AM
RedLeader289
05-28-2019 01:47 PM
Luigytico09
10-01-2015 08:46 AM
ironbmt
09-27-2015 06:00 AM
6998poncho
09-25-2015 02:56 PM
Quick Reply: 700r4 acting funny....PLEASE HELP!
