Pics of my T5 swap (Picture Heavy)
Car: 91 Z28
Engine: TPI 350
Just wanted to share some pics of my T5 swap I performed during x-mas vacation
Some of the pics were taken with my cellphone 'cause I forgot my digital camera at home...
th700 removed:
in goes the pilot bearing (Moroso):
and the GM Performance Lightweight Flywheel:
Centerforce Dual Friction with the Centerforce Align Tool. The tool has to go in and out without resistance or you will have a hard time getting the tranny in because the clutch disc is not properly centered. the t5 virtually slipped in when I mounted it later...:
In order to get the bellhousing on I had to grind the starter because it is the big one for an automatic tranny. After that it fit fine. Here's a pic after grinding and painting:
Bellhousing:
th700 removed:
Bellhousing:
Moonan55 (09-06-2024)
Car: 91 Z28
Engine: TPI 350
Re: Pics of my T5 swap (Picture Heavy)
Removed the Auto pedals and installed the manual assembly with the braces. I cut a template of the foam gasket that was on the GM Clutch master cylinder from cardboard so I knew exactly where to drill the holes for the cylinder (pita). To do that, I removed the pedals as well as the Brake Booster.
pedals mounted:
For the shifter-hole I placed a used lower shifter boot on the tunnel and marked where the holes for it go. after that I marked where to cut. You can see the marks for the holes on the pic. After testfitting the tranny I found that it was very close on the rear of the hole so I enlarged it on the back. In the pic you see the finished hole. I cut off the sheetmetal on top that was for the shifter.
Tranny mounted as well as slave cylinder with its bracket:
Console with shifter (yeah I need a new **** as well as a leather boot):
I found this an easy conversion although I really took my time and did a lot of research. Luckily I could do this at the workshop where I work (Mitsubishi Dealer) so I had a bunch of tools and a hydraulic ramp
The exhaust hanger for the original dual cats does not fit. It's to short. I have to fab something!
Hope this thread is helpful to anyone!
pedals mounted:
Car: 91 Z28
Engine: TPI 350
I rewired one wire from the rear hatch switch to the emergency brake wire right at the bottom of the lever so it is grounded when you engage the e-brake. It's the one wire that has no electrical potential when ignition is on (the other one has).
On the shifter connector I connected the two big wires (starter switch) and did not rewire them to the clutch pedal.
The ones for the ECM (they are striped) I left alone (of course I insulated them)
the remaining two are for the backup-light switch. rewired them through the original hole for the auto-shifter cable with a grommet I found in the shop!
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
What would be easier to do, widen the automatic floor for the shifter, or just cut the hump out of a car that came with a manual?
Car: 91 Z28
Engine: TPI 350
thanks,
yeah I wanted to go T56 too at first. But you really have a hard time to find them in europe. and when you do find one the price is usually not worth it.
this used t5 was expensive enough.
I think cutting out is easier but if you have a manual car where you can measure the hole dimensions and location you'll be lucky. but it came out really nice like I did it.
I still need a 18tooth driven gear for my electronic VVS in order to get my speedo working
Car: '84 Camaro
Engine: 5.3l TSP 224r
Transmission: TH350 3600 stall
Axle/Gears: LS1 3.23
I think they flywheel is Summit# NAL-14085720, I think it's the same one I've got. Nice write up, I plan on doing this swap in the next week or so. These pictures should help a lot.
https://www.thirdgen.org/forums/exha...ger-fix-p.html
JamesC
Car: 89 trans am GTA,90 model trans am 350 tuneport,87 firebird
Engine: 355 small block
Transmission: 5 speed,auto 700r4
I did my swap some time ago,great pics.I found a web site to be helpful,it was FBODYMOTORSPORTS,it is YOUNGSFBODY NOW,they have a complete write up and pics of the T5 INSTALL in a camaro.
Car: 1992 Chevrolet RS Camaro
Engine: 305 TBI
Transmission: WC T5 conversion
Axle/Gears: Debatable . . .
Car: 91 Z28
Engine: TPI 350
Summit# NAL-14088646
As for the clutch I really like how it feels. very easy to engage. Don't know how it holds up since I'm breaking it in now for about 500 miles with the new flywheel. But from what I read about it it should be no problem for my stock L98 haha...
Car: 91 Z28
Engine: TPI 350
Maybe the following will help, maybe not:
JamesC
JamesC
little bit off topic but thats an awesome looking T/A. you got a page with any pics?
I have some pics on this site,it is in the FIREBIRD section. It is in the Auto Detailing and Appearance section,then under FIREBIRD PICS.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
My car had the wiring for the clutch switch already, it was behind the drivers side kick panel near the bottom of the dash.
I just plugged in the switch and mounted it to the pedals.
1 Post
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
Benny, I need a favor...
I was wondering if you had side pics.... I need to know how much the trans sticks into the car, to mak sure it's not mounted too high into my car, before i cut sheetmetal. right now, it looks as if the top of the trans (where the shifter is) sits about an inch or two into the cabin... is that correct?
1 Post
Car: 72 Malibu, 89 RS & 04 Z71 extended
Engine: (2)350's & 327
Transmission: auto/T5
Axle/Gears: 4:11, 2:73 & 3:73
great thread. Just picked up a whole t5 set up from tpi-hearse and will be swapping over soon. That dude has tons of 3rd gen parts.
Car: 91 Z28
Engine: TPI 350
If you have the correct crossmember (auto/manual is the same) it'll be alright!
Sorry I do not have a pic of that!
1 Post
Car: 1982 Trans Am
Engine: 383 chevy
that's ok, you answered my question.... I need to cut the hole first. I'll get to that next weekend. thanks a bunch.
Car: 1982 Pontiac Trans Am
Engine: 305 V8
Transmission: TH200
im doing my T5 swap next month, ps...anyone reccommend some1 in the toronto, ontario (canada) area to do a auto-5spd swap? so far ive found a guy whos willing to do the swap for $1000 for labour.. (but he's also installing my 350 engine included in that price)
1 Post
Car: 1982 Trans Am
Engine: 383 chevy
I'd go with him, this is an easy swap, but for $1000..... that's a good deal.
Car: 88 iroc
Engine: 355 tpi
Axle/Gears: 3.27 borg warner
Do you have any issues with the idle? My buddy did when he switched over to a T5. But he did not connect the neutral safety switch and something else.
Nice write up!!
Mark
Nice write up!!
Mark
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
when you swap in a t5 do you have to change anything with cars ecm computer? to tell it theres a manual transmission?
Car: 85 Iroc-Z
Is the torque arm mount definetly different from the automatic compared to the manual one? Or can you make the automatic one work?
Car: '89 GTA/'86 TA/98 TA
Engine: 350/350/LS1
Transmission: R4/T5/4L60E
Axle/Gears: 3.23/2.77/3.73
this sis going to be very helpful over this weekend, just 1 question for the pilot bearing what do u put on it?? just bearing grease? thanks
Car: 86 Iroc-Z28 Camaro/84 BMW M Power
Engine: 350TPI/ S50
Transmission: t-5 five speed/ 5 speed
Axle/Gears: 3.42 posi/ 3.73LSD
Unfortuanately it is a dealer only item too. so if you dont have the correct one from the car you got the trans from your screw its like $80 from GM. Good thing i saw Benny K got the right one.
Engine: 350TPI/ S50
Wow just notice this is like a year old. whoops!!!
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
I have a few questions about my swap.
1. I see you had to modify the starter, does anyone have the part number for a stock manual starter? My starter is on it's way out so I might as well replace it.
2. Did you reuse the flywheel to crank bolts, or replace them? If you replaced them, where can I find the correct bolts?
3. Same question as 2, but clutch pressure plate bolts. I know I don't have these, what kind do I need?
4. What's the part number for this manual torque arm mount as I will likely need one?
5. Does anyone no the part number for the clutch fork dust boot and the slave cylinder heat shield?
That's all for now, any help is greatly appreciated.
Car: 91 Z28
Engine: TPI 350
Mine came pre-greased with some kind of special grease.
1. Get some mini high torque starter from Summit or something. In order to get the automatic starter out of the car you have to remove the bellhousing (it was a temporary fix, I had to rebuild the tranny later on and replaced the starter then)
2. / 3. new bolts, from Summit. I think it was Mr.Gasket and some other brand.
4. Just give your dealer a call. I didn't see aftermarket mounts...
5. Those parts were out of stock and not reproduced when I asked my dealer. I got them off eBay.
hope that helped!
Car: 89 Camaro RS
Engine: LO3 TBI
One last question, is there a plate I need to get for the bottom of the bellhousing to keep road debris out?
Cover, Flywheel hsg (MB1) GM 14036055)
BTW, 84-91 Boot, Clu Fork GM 14007355 is a good number on http://www.gmpartsdirect.com/index.c...TOKEN=43475709
JamesC
Engine: 350TPI/ S50
Gm Part Numbers are as followed
Bracket A 10252375 List price 33.04
Insl Supt 10252374 List price 48.14
I bought these from a dealer in april 2009, they were special order, they were no longer made but they were able to find them somewhere in some dealer ship in tennessee for me. so you may still be able to get them from the dealer.
Sorry it took me so long to get back here haven't had much time these days.
Car: 1987 Monte Carlo SS
Engine: Vortec headed 350
Transmission: '89 WC T5
As far as the starter, couldn't a person use a stock LT1 starter? I thought I read somewhere that they are smaller and perfect for this sort of thing.
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
i've been thinking of doing this conversion,,,i have some questions...do you need to change the drive shaft from a 700r4 to the T5?....the cross member trans support needs to be changed?..and what other difficulties i can expect?...thanks...
great job BTW!!
great job BTW!!
#42
Transmission: T5 WC
ok thanks for the quick response..any other things i should know?...like the speedo cable?....the clutch cable....is it hydraulic?...or just a cable?...or the throttle cable is the same fro an auto to t5...anything that would be needed to look out for before i do the swap..thanks.
#43
1 Post
Car: 1982 Trans Am
Engine: 383 chevy
do a search, there's a sticky with info that will answer most, if not all your questions in the trans forum. your questions have been asked and answered 100+ times.
#44
Thats weird you had to drill hole for the master cylinder. when I did my 82 it had a hole there already and I just enlarged it a bit then drilled the two small holes for the "U" bolt
#45
Engine: None
Transmission: None
I just removed my 700R4 for my T5 swap. What are you using to keep your motor level with the rest of the car? I have a jack under the oil pan to keep it level.
#46
Transmission: T5 WC
hi , i just removed my 700r4 on my 350 1985 camaro,,,i took a measurement of the 700r4 flywheel and it is 14' across...the one i got with the T5 is 13'....i thought they are the same for a 305 and 350...where do i get the right flywheel and is this a common issue?,.thanks...help!!
#48
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
I want to do this swap but only have myself. Im most concerned with is can one person do this if so how can I remove the tranny without killing myself and reinstalling the t5? or should I bring it to a tranny shop and let them drop the 700 and install most of the t5? Can this be done or ramps or should I use jackstands?
#49
Engine: 350/350/LS1
Both jacks and ramps, if your doing it on the groundyou will need a jack and jack stands for holding up the engine and the jack for the trans. It can be done alone, just be careful
#50
Transmission: T5 WC
