Transmission for 383 stroker in a 87 IROC?
Car: 1987 IROC Z28 1le brakes
Engine: switching to 383
Transmission: installing tko 600
I have been told my T5 transmission will not hold up once I drop the 383 I am rebuilding in. I am getting different stories about what I really need to install a T56 and what it cost. Additionally the TKO 600 I get different stories on as well. What is the best transmission (not driving long highway miles) for a 383 in an 87 Z28 IROC? What is the best for the money? What additional parts are a must for conversion? and where is the best place to find them?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Transmission for 383 stroker in a 87 IROC?
The largest engine GM put the T5 behind was a 305. If GM didn't put it behind a 350, think what a hopped up 383 will do to it.
A T56 is a better option.
so t56 beats the tko as well you are saying? if so any ideas on what I truly need to complete the swap. The fly wheel I have on the 383 was for a automatic so I know that will not work. The driveshaft looks like it will have to go down 2 inches. Do I need to change yokes? Bell housing? What about the VSS?
The T5 will not blow up just because you put a 383 in front of it. It will blow up because you beat on it at the track or on the street.
Read the two tech articles on swapping a T56 from a T5 and an automatic. They will aswer your questions.
ok thanks. Now I have to hunt the stuff down that it mentions in that article. Everything new looks like about $3600. Hopefully can get stuff cheaper, but not likely
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Yep, i beat the **** out of my T5 behind my 383, but if i went to the track on slicks i thgink that would be its demise.
I was reading on this site that you did take your t5 on a track with slicks and dropped it at 5000 rpm and you were fine...
![hmmm](https://www.thirdgen.org/forums/images/smilies/hmmmm.gif)
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Yea, i did....with a 357 (.040 over 350). Made about 375 flywheel HP. My 383 is closer to 500.
Good to know. On my 383 I am sticking with cast iron heads and expect only to be around 420. Given that, I can baby the t5 around for a while and get the stuff done on the house my wife wants first.
By the way I could not find tech articles on the Richmond 5 speed transmission. A book I read tonight said that this was a good option in a 3rd gen up to 600 hp. Any opinions on one of these?
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Richmond is Richmond, aftermarket is as nice as it gets of course. I still beat the hell out of my T5 with this 383, but i maintain a stock clutch and radials(which are still 295 wide). I have 70 iron heads that are so hogged out that i had to open the intake gasket to make them match.
Car: 1991 Gta trans am
Engine: 383ci,trickflow alum. heads, hsr
Transmission: T-56, alumin. driveshaft
Axle/Gears: stock 7.5"/3.42
Go for the T-56 you wont regret it. I did my whole swap for about $1800, transmission was used at 80,000 miles and came with the flywheel and I got the 4th gen pedals from a junkyard. But I couldn't find the slave cly anywhere so I went to a chevy delear to get that. Just keep your eyes open for deals because I got my tranny off ebay and only paid $1100 for it.
mhatfield 14
10-24-2015 07:48 AM
Mickeyruder
09-02-2015 02:45 PM
mustangman65_79
08-11-2015 03:17 PM
