welding the spider gears?
Old 11-14-2007 | 06:25 PM
JCL91TRANSAM's Avatar
Car: 91 Trans Am
Engine: 355 l98 mini ram
Axle/Gears: stock10 bolt 3:23 gears
My factor posi unit is gone and I am a one wheel wonder right now. I just want to make one more pass at the track before the season ends and a buddy of mine told me to weld the spider gears since I do not have the money for a new posi. Now I do plan on having a whole new rear end by the time the new racing season starts so maybe its not a bad idea. I heard of people doing this alot but I cant see this being a good thing. What do you guys think?
Old 11-14-2007 | 06:41 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: welding the spider gears?
Don't do it.
Old 11-14-2007 | 07:15 PM
royslsbry's Avatar
Car: 1992 RS
Transmission: 700r
it ok for drag racing i have done and had no prob at the track driving it on the road felt like the rear end was sliding around i wouldnt do it if i was going to drive it on the street
Old 11-14-2007 | 07:25 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Don't do it at the track either. It's illegal under NHRA and IHRA rules.
Welding the spider gears is difficult to do safely, and if done wrong will cause breakage that's likely to lock up the rear wheels and send you spinning out of control.
Old 11-14-2007 | 07:33 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Welded spider gears are normally in off road only 4x4's or dirt track race cars where they need locked axles but will never get 100% traction.
As mentioned above, they're illegal in IHRA and NHRA and you don't want locked axles in a street car.
Install an open carrier then install something like a Powertrax into it.
Old 11-14-2007 | 07:52 PM
Car: 91 Trans Am
Dont worry I wont do it. I thought about it but I wont go through with it, ecspecially if it is against NHRA rules and for my own safty too.
Old 11-14-2007 | 08:56 PM
AlkyIROC's Avatar
Car: 87 IROC L98
I had the spider gears welded in my old 10 bolt for a season. Nobody knew about it. Not everyone has the ability to weld them up properly. I had them professionally done by a welder who knew what he was doing. He also used a high quality steel rod. It's not something you can do with a MIG welder.
Old 11-15-2007 | 01:28 PM
Shagwell's Avatar
Car: projects.......
my 4.3 chevy in my nissan 4wd toy broke a welded carrier w/ 35's in the slop..... Now you want to do it with a weaker rearend and attempt to hook it?
Either locate a rebuild kit for your posi or upgrade to an aftermarket unit.
Old 11-15-2007 | 03:41 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
With one race left ya might as well just use the open and get some practice launching the car with less than normal traction.
I imagine the time has passed already anyway...
A mini spool is available for $90. Marginally better than welded gears.
F-body driver
03-06-2023 12:44 PM
db057
04-28-2019 08:45 AM
fasteddi
09-10-2015 10:32 AM
rudolphschenker
09-04-2015 03:41 AM
UltRoadWarrior9
09-02-2015 09:24 PM
