Rebuild kit for rearend
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
I need to know who sells parts so that I can put new outer bearings and c-clips into the car. The gears should be fine and I think that the inner bearings are fine too. My outer bearings are starting to squeek and the axels have bad side to side movement. I at least have to do that. I am trying to spend as little as possible on this and I figured that the outer bearings and c-clips are pretty cheap. The rear is in my 89 RS V6 auto. It has a 3.42 open diff.
1Aauto
Sponsored Vendors
01-15-2016 06:26 AM
tonys91rs
10-10-2015 03:31 PM
