Will My 3rd Gen Gears Fit Into My 4th Gen Rear?
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
I have a 89 Camaro RS with I believe 28 spline axles. The rear has 3.42 Strange gears and an Auburn diff.
I was thinking of buying a 4th gen rear (would like to put wider tires out back)
Will the gears and diff. from the 3rd gen fit into the 4th gen rear or not?
Thank you..........Bill
Re: Will My 3rd Gen Gears Fit Into My 4th Gen Rear?
all you need to worry about are the spline count. If indeed you have 28 spline axles, then yes, the diff and gears will be perfectly fine.
Car: 88 Firebird WS6
If you never changed the axles and just did the gears I would drop a good bet on it you have 26 spline axles. Stock some late 90's had them, 91&92 always have the 28 spline axles. Since the gears and diff are aftermarket it WOULD have been wise to goto the 28 spline axles but auburn does sell a 26 spline diff that won't work. Then you might be able to save the gears, although many cringe at the fact of putting used gears on a different setup....
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: 700R4 w/transgo 700 shift kit
Axle/Gears: 3.42 posi
I've heard a few of the very late model 89's had the 28 spline rear end, probably the only way to figure it out is to pull the axil and count.
sailtexas186548
01-19-2016 12:21 PM
hectre13
08-26-2015 08:17 AM
Iroc8t8
08-26-2015 08:14 AM
