slipping clutch!! which must i buy????
1 Post
Car: camaro iroc-z
Engine: 355 L98 Corvette engine
Axle/Gears: 3.27 9 bolt borg warner
hello
i have a 88 camaro iroc-z
5.0 V8 with a t5 manual transmision!
my clutch is slipping in 2nd and 4th gear!
i want to buy a new clutch somewere (ebay or something)
but witch clutch can i best buy??
the engine is all stock but in the future i want swap some parts
i was looking for a racing clutch!
is that oke???or what can i best buy!!!???
please who can help my with my choise
gr Dennis
gr Dennis
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
Re: slipping clutch!!witch must i buy????
Depending on your needs ur going to have to look at what the manufacturer recommends( As far as like, Stage 1 etc should have a description), Id Say Spec, Ram and Center force are a good way to go.
1 Post
Car: camaro iroc-z
okey and where can i find these parts???
how much will these cost???
and is this much better than the stock clutch (a light race clutch??)
thanks dennis
thanks dennis
Re: slipping clutch!! which must i buy????
If you can afford about $300, the Ram Powergrip clutch is an awesome, all-around performance clutch. For that matter, even the Ram OEM replacement clutch is probably better than the originals. I've run several different clutches in my 69 Camaro over the years, and the Ram Powergrip has been the best one hands down.
Car: projects.......
some parts houses carry Brute Power, which is the same manufacturer as Zoom clutches. They are a great up-grade replacement clutch for a medium duty street car. - they're also lower $ when compared to an aftermarket performance clutch, which could easily be in need of replacement by the time you actually need it(unless you start throwing a bunch of mods at it real soon).
Drone358
12-10-2015 08:16 PM
Night rider327
09-02-2015 04:17 AM
