700r4 from camaro to silverado
Car: 85 camaro z28
Transmission: T56 6 speed
Axle/Gears: 3.27 borg warner 9 bolt
will a 700r4 from a 85 z28 hook right up to a 88 chevy silverado or is there somethings i must know about first?
1 Post
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
Re: 700r4 from camaro to silverado
I dont recomend that swap at all, if it were an 87-up perhaps but the 85 wasn't really strong enough for that amount of weight.
The 85 in stock form is a weaker unit however the swap itself should be pretty straight forward. There may be a minor difference between the converter cover bolts
