automatic 4 prong connector, what's it do?
1 Post
Car: 89 IROC convert.
Engine: tpi 305
Axle/Gears: 3.42 10 bolt
I just changed from an auto to a T-5 in my TPI 5.0 camaro. There was a four prong electrical connector going into the side of the auto, which is now dangling under the car.
I assume two of the wires are for the backup lights. What are the other two wires for, and what do I need to do with them?
Also which wires run the backup lights, and can I get a two prong connector to go into the side of the T-5?
Thanks much.
Thanks much.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: automatic 4 prong connector, what's it do?
The backup light switch on an automatic car is on the shifter. The 4 prong connector is for the torque converter clutch and the 4th gear switch for the ECM.
Car: '89 Firebird Formula
Engine: 305 TBI
the reverse lights were controlled by automatic shifter itself, the wires are on the harness that connected to the shifter, I dont recall which colors.. the 4 prong connector you can just tape out of the way somewhere, it was for your converter lockup
ooo, beat by 1 minute, you dirty rascal ;0
IROCZDAVE (88-L98)
11-19-2015 07:03 AM
