c-clip or bad axle?
Old 08-31-2007 | 09:49 PM
meyer30's Avatar
Car: 1992 T/A
Engine: 5.7l 355
Transmission: 4L60
c-clip or bad axle?
Well I've got a 92 T/A with the 3.23 gears, I've been hearing a grinding noise when making a left turn coming from the right wheel. First thought was the axle bearings. Well when I changed my brake pads I noticed a nice groove cut into the pads, couldn't figure out why tho. Well I got the new bearings, pulled the right axle installed the bearing and noticed the c-clip. The clip has a groove cut into the top portion on one side and a nice wear pattern on the other. Is there a way to tell if it's just the c-clip that is bad or is it the groove in the axle? Is there a thickness I can measure for? I appreciate the help. Thanks
Old 08-31-2007 | 09:52 PM
92droptopws6's Avatar
Car: 90 RS
Engine: 5.0 TBI
Transmission: Slushbox
Re: c-clip or bad axle?
for the price i would instal NEW GM c-clips to see if the noise goes away.
while you are in there pull the carrier out and inspect the bearings and races one of those two and i think you will find your problem.
Old 08-31-2007 | 10:00 PM
meyer30's Avatar
Car: 1992 T/A
Engine: 5.7l 355
Transmission: 4L60
thanks for the reply, can't seem to find the c-clips anywhere, I'll have to check with gm tomorrow.
Old 08-31-2007 | 10:14 PM
Car: 90 RS
Engine: 5.0 TBI
definately get the GM c- clips.
Old 08-31-2007 | 10:36 PM
meyer30's Avatar
Car: 1992 T/A
Engine: 5.7l 355
Transmission: 4L60
you wouldn't happen to have a part # would you?
Old 09-01-2007 | 10:17 AM
meyer30's Avatar
Car: 1992 T/A
Engine: 5.7l 355
Transmission: 4L60
Alright I've been looking all morning trying to find these damn c-clips and I can't find anything. Does anyone have any idea where someone could locate them? thanks
dbrochard
10-03-2015 01:43 PM
xXIROC ZXx
Wheels and Tires
09-16-2015 12:18 AM
scottmoyer
09-07-2015 08:06 PM
dbrochard
09-07-2015 10:41 AM
rudolphschenker
09-04-2015 03:41 AM
