88 iroc vert rearend
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Transmission: 700R4,700R4
Axle/Gears: LSD,LSD
car is pretty much junk but runs and drives...has no rpo codes what so ever thanks to no interior...i get it running and of course... i wanna do a burn out and it has an oddly sized bigger tire on the left rear...different than all the rest...both the tires start to spin...slowly..and then the left stops and the right one kicks out...can someone explain?? or should i just jack it up and pop the cover off????
Car: '91 RS
Engine: 5.0L gross *** tbi
Re: 88 iroc vert rearend
only way you will really know is pop open that diff cover but.... that deff sounds like posi to me its the bigger tire is throwing it off. didn't think that was good for your rear anyways(driving w/ 2 diff sized tires on rear)
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Axle/Gears: LSD,LSD
ha!..popped it off and its an LSD!!..can those be beefed up at all rather cheaply?
mustangman65_79
08-11-2015 03:17 PM
