b&m clutch turbo
Car: 1984 Camaro Z28
Engine: 350 from an elcamino
Transmission: stock t-5
Axle/Gears: 10 bolt 3.73 limited slip
b&m clutch turbo
what about using a b&m clutch turbo with a manual valve body in an 82 z28? where would i find one? i did a quick search, and only got about 4 results on google.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: b&m clutch turbo
Contact this company.
www.wintersperformance.com
http://www.wintersperformance.com/ca...eWinder/31.htm
winters may be able to help you, but B&M sold off all the tooling for the clutch turbo's years ago and has no plans of doing it again. They leaked fluid, broke bellhousings and were kind of a cluster f#*k to assemble. The problem is the pump has to turn all the time which is very difficult to achieve around/through the clutch linkage.
If you want a clutch, why not just put in a manual trans and learn to shift it? I shift clutchless.
i have a 5 speed now. i was going to do a full manual valve body anyway
