4th gen rear end???????
Car: 92 Formula 350
Engine: L98 with a T-76
Transmission: ArtCarr 700-R4
Axle/Gears: Bone stock 10bolt and 3.23's
My brother got a 4th gen rear end from a junk yard to put in his 91 z28. The car was a 94 3.4v6 auto, firebird. Any idea what the stock gear ratio is? Thanks
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Re: 4th gen rear end???????
my guess is 3.42 but non posi. else its 3.23...those are the two most popular ratios.
just take the cover off and look
Right....
Since you'll be taking the cover off anyway to change the fluid, like anyone with any degree of common sense would surely do THE VERY FIRST THING after getting some junk part before they put it in their car, this post was basically a waste of bandwidth.
Car: 92 Formula 350
Thank you so much! I just wanted an idea of what gear it had a$$hole. The rear end is in the car and didnt pull the cover yet. So instead of lifting the car, laying on the ground pulling the cover right now, i figured i could just simply ask someone.
You mean he and already put it in the car without changing the fluid???
I hope he realizes that alot of junkyards these days, drain all the fluids from cars on their lot; so it might not have any in it AT ALL. He might have zero choice other than laying under the car, in that case.
Car: 92 Formula 350
hectre13
12-11-2023 09:14 AM
1992rs/ss
05-19-2020 08:02 PM
1992rs/ss
16
01-28-2016 10:58 PM
AkDrifted
08-17-2015 08:45 PM
