kickdown cable= tv cable
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
ok the th350 kickdown/passing gear cable is a pita to get adjusted right so would it be possible to use the 700 tv cable as they are the same basic design?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: kickdown cable= tv cable
Probably not easily, although later TH350s did use a similar kickdown cable.
Engine: 383 Carb
Transmission: 4L60
You can install the cable on the transmission, but I don't know how easily you could get it to work as you expect.
Z28/ZR1
10-23-2015 01:04 PM
TMZIrocZ350
10-07-2015 12:09 PM
