Broken tooth on pinion gear
Old 04-25-2007 | 02:51 AM
WestOzGTA's Avatar
Car: 87 Trans Am GTA
Broke off half of a tooth on my pinion gear... just wondering how bad it is to keep driving the car (with the broken bit removed obviously) until I can fix it. And when I do fix it, is there anything else I should definitely do other than new ring & pinion gear set, pinion bearing, seal, crush sleeve... ?
Thanks,
Stu
Old 04-25-2007 | 04:20 AM
ede's Avatar
ede
Re: Broken tooth on pinion gear
well you know the right answer is don't drive it and get it fixed. first gear set i ever set up was for a racing buddy and we both weren't sure i could do it so he gave me a gear set with 4 or 5 teeth on the ring gear broken and chipped. he raced most of the year on it and drove some on the street. he finially went to a 4:88 and ran in the 11s and carried the front when he launched with the 4:88s i set up.
db057
04-28-2019 08:45 AM
GouldyGTR
09-07-2015 10:05 PM
snakeshooter
09-07-2015 12:15 PM
rudolphschenker
09-04-2015 03:41 AM
UltRoadWarrior9
09-02-2015 09:24 PM
