u-joint angle
Car: 1991 z28
u-joint angle
is a 1inch drop going to shift my drive shaft enough that I will need to correct my u-joint angle's?
Car: 91 formula converted to ws6 ta
Engine: 350 chevy
Transmission: 5spd
Re: u-joint angle
you want the pinion angle to be 0 degrees if you are driving on the street daily not much racing that will insure the least amout of loss and wear on the joints when crusing. How ever for drag the pinnion angle must be figured in the squat position to avoid wheel hop and reduce inital stress on launch. normally 1 inch of drop is not a big deal on a thirdgen. it is only about 2 deg diff in pinion angle.
[GA] Shorty headers
Night rider327
09-16-2015 02:20 AM
