torque bar?
torque bar?
the bar that runs from the rear of the tranny to the front of the rear end along the drive shaft. how do i install it? i have the drive shaft off and the car on a set of ramps.
Re: torque bar?
I put the drive shaft in then put a jack under the diff and jack the rearend up.. this will aline the diff with the trans.. then just bolt and go.. If I left something out please add.
Re: torque bar?
actually to be more precise how do i mount it to the tranny?
Car: 87 TA
Re: torque bar?
Not sure about any aftermarket torque arms, but the stock ones just slide into a rubber gromet that bolt to the trans. I've always just slide it into the grommet then bolted it up to the rear from there.
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: torque bar?
there should be some sort of clamshell-type mount with integrated rubber bushings, that hinges on the bottom and can be bolted shut on the top.. there will be 3 bolts on it.. lets see if i can get some kind of picture.. theres what it should sort of look like.. 2 bolts on the bottom through the bottom of the trans tailshaft, and one up top to hold the mount closed..
Re: torque bar?
Here's a pic that will provide the general idea:
https://www.thirdgen.org/forums/atta...what-drive.jpg
JamesC
JamesC
no green
01-09-2016 09:22 PM
