TINK! noise when shifting into Reverse = "infamous clunk" ??
Car: 86' Z28 Camaro
Engine: 357 TPI -- Dart Heads -- Voodoo Cam
Transmission: Built 700r4
Axle/Gears: 3.23 Posi
I'm not sure if this is classified by the "infamous clunk" because it really isn't a clunk, it's a very distinct TINK noise, like dropping a hollow pop can from 100 feet and letting it hit the ground, it's exactly like a TINK.
It's a 700R4 with 95000 miles on it. It used to happen once and awhile when shifting into reverse and very very rarely into drive. But lately it'll do it quite often when shifting from park to reverse, it happened the last 5 times that I put it into reverse.
1. Does this spell out trans mount?
2. U-joints?
3. Rear end?
I've read countless posts about clunking noises, but i'm not too sure if it's the same thing...
2. U-joints?
3. Rear end?
Car: 91 Camaro RS
Engine: Small Block
Transmission: TH350 w/ 3000 stall convertor
Axle/Gears: 3.73 w/ powertrax locker
Re: TINK! noise when shifting into Reverse = "infamous clunk" ??
Well i sure hope for your sake its the u joints instead of the rear end!
Car: 86' Z28 Camaro
Do you know of any ways to check these out easily?
Received 1,864 Likes
Get up under the car and look.
Try parking the car over a gutter by finding a tall curb next to a driveway, and driving the one side of the car up on the curb.
ALthough with a U-joint, it's hard to tell by looking, or anything else you can do by hand; they can be falling-apart dead and still look OK from the outside. Best way to check em is by replacement. If you haven't replaced them lately, they need it anyway; so don't bother "troubleshooting", just shotgun it.
sjorgens
10-01-2015 07:54 PM
