turbo 350
Car: trans am ws6
Engine: something special :)
Axle/Gears: 4.10 posi
turbo 350
alright well my 91 firebird has a 700r4 in it. my question is, i can get a free trans and its a newly rebuilt turbo 350. its out of an 88 ck pick up. would it work in my car at all? im looking to put a turbo 350 in it, but will this one work out of the truck? thanks
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
you need a different Driveshaft, torque converter, and either a new tranny crossmember or a torque arm relocation kit. and a different shifter/ shift gate for the stock shifter. depending if you want you're speedo to work you'll need the appropriate conversion kit
hey he doesnt ned a different shaft if he uses the right length of th350
ppl dont seem to understand this for some reason
9" tail th350 is the same as a 700r4
also an 88 would not have a th350, not from factory
none existed in 88
the th350 went away in 86
and you dont have to swap the shifter, the 700r4 shifter will work just fine, just that you will have an extra range on the shifter that is unused, the shifter will work just the same, jut fine
move the crossmember forward
have to get 700r4 to th350 brackets for the TQ arm mounting
none existed in 88
Car: trans am ws6
well i thought it was a 700r4 but he went to sell it to a kid and the kid is like no its not a 700r4 its a turbo 350 and returned it. so how do i know. he will give it to me if i can get it to work. cause my tranny is going. is there a way to tell which tranny it is? thanks
700r4 = 4 spee auto with overdrive
th350 = 3 speed auto no overdrive
totally different trannies
700r4= deep and huge rectangle pan and with square plastic wiring plug in, 16 bolts
th350= corner hacked off the pan and no plastic electrical plug at all, 13 bolts
there is a flat spot somewhere along the pan rail or near the bellhousing with a code stamped in it, the first digit will bea number, it is the last number of the year of the tranny
for example if it starts with 6 then its either 1976, 86, or 96
good luck
good luck
Car: trans am ws6
hey thanks guys. also if it were to work, i have to get something else so my spedo would be accurate?
Car: trans am ws6
alright i looked at it, and its a 16 bolt, with a plastic plug outlet thing, and has a long rectangular pan. its out of a 88 so would it work in my car. or would it be easy to make it work cause i can get it for free or hardly nothing.
all gm output tailshafts are the same except for the th400 derivatives, 475, 3L80, 425 etc and the top loader manual trannies like the CH465 and SM420 and NP435 and so on
good luck
good luck
Re: turbo 350
oh ok its a 4x4 one
nope wont work
4x4 doesnt have or use an output shaft housing
the four bolts that bolt outputshaft housings for 2wd vehicles are used to bolt the adapter to it instead of the shaft housing
plus the 4x4 shafts are shorter than the 2wd ones
you need a 2wd 700r4
heres a 4x4 one i hd not too long ago, and the adapter for the transfer case:
heres a 4x4 th400
heres an old th350 bolted to a 203 case:
good luck
nope wont work
heres a 4x4 th400
good luck
Car: trans am ws6
Re: turbo 350
so there is no way at all i can get this to work then? i wish i could find a good tranny around here some where.
Re: turbo 350
nope
the only way possible is if you could hire someone to tear down that tranny and put a 2wd output shaft in it
the shaft is the first part that goes in the case
good luck
good luck
Eric-86sc
08-24-2015 09:01 PM
