Using a stock speedo cable w/ aftermarket guages
1 Post
Car: Only a daily driver, but comin home
Engine: I have one that runs ;)
Transmission: Caged hamster that runs really fast
Axle/Gears: They are round, I know that much
Wondering if it is possible to run an aftermarket speedo and use the stock speedo cable? Or if anyone knows if the stock mechanical speedo pick-up can be used with an aftermarket cable?
Trying to do things with as many stock parts as possible, so any input is appreciated!!
Thanks ahead of time!
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
yes they have aftermarket mechanical speedometers that you can just plug your speedo cable into.
Car: 1985 z-28
Engine: 350ci
Transmission: 700-r4
Autometer threaded speedometers (mechanical) ones require a screw on style GM cable. I used one made by ATP cables. Part number ATP-Y803 (its like $12). Its for a 1970 c1500 truck I think. I think 1959-1971ish is the screw style plug. WOrked with my autometer gauge and th350 tranny. But should fit a 700r4 mechanical as well.
1 Post
Thanks tommy z-28, I have a th350 so that will work, any place in particular I pick one up? Certian part store chain?
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Re: Using a stock speedo cable w/ aftermarket guages
Is the stock speedometer in an `88 Iroc 350 TPI electronically operated or by a cable? Thanks
Car: 1988 Iroc
Engine: 383 TPI
Thanks for the info. Is your car the factory metallic dark red that most people call burgundy? Great color, same as mine.
700r4, aftermarket, autometer, cable, cj, fit, gm, mechanical, plug, speedo, speedometer, stock, tpi
