Lets play, whats my driveshaft
Car: 1984 Trans Am
So I got an aluminum DS off Ebay hoping to fix my vibration problems. I was reading thru a bunch of old posts about aluminum DS's and nothing adds up to the shaft I have. So somebody tell me what I got, and please don't tell me what I got was screwed.
Three Rivers sticker 12560725, 3 inches diameter, 40 3/4 inches center to center on the u-joints. U-joints are the normal kind with the c clip on the inside and it has the damper on the trans yoke like the LS1 pictures. So what is it?
My buddy got an LS1 shaft for his car from a local junkyard, and it also had the Three Rivers sticker on it. I'm pretty sure that's who made the LS1 shafts. I can't remember the part# exactly off the top of my head, but yours looks familiar. I'll have to ask him what the part# is on his when I talk to him later today. In fact, now that I think about it, the reason yours is slightly shorter is probably because of the vibration damper on the slip yoke.
I knew I had a pic of the two somewhere. This is a pic of a 1LE and a LS1 shaft next to each other. The LS1 shaft does look a bit shorter to me in the pic. It looks like the yoke ears on the ends of the shaft are not only beefier, but longer than the ears on the 1LE shaft, which would explain the actual tube being shorter.
Car: 1984 Trans Am
Thanks Pat, that's exactly what mine looks like. From the part number, it must be really early in the run. No matter, it's still got to be better than the steel.
![thank you](https://www.thirdgen.org/forums/images/smilies/thanks.gif)
![your welcome](https://www.thirdgen.org/forums/images/smilies/welcome.gif)
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
IROCZDAVE (88-L98)
11-19-2015 07:03 AM
