Where can i find aftermarket gears for a Aussie 9 bolt rear?
Old 02-09-2007 | 11:35 PM
kbog54's Avatar
Car: 1983 Z-28
Engine: 305 CFI
I need a few good sources for aftermarket 9 bolt rear parts, 9bolt.com seems to be down or out of business and summit only lists one set...
Old 02-10-2007 | 12:09 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
9bolt.com became www.diffsolutions.com but I don't know if he's still in business.
Old 02-10-2007 | 12:17 AM
88TPI's Avatar
Try these guys...
TACREATIONS USA:
Phone (305) 769-0985, Fax (305) 769-0932, E-mail : parts@tacreationsusa.com
Carriers have 4 categories associated with them. First, a ring gear size (7.5" & 8.5"). Second, a bolt count (9, 10 & 12). Third, a numerical denomination of a series (2 & 3). And finally, carrier type (open, limited slip, & torque sensing). Each one is unique and requires certain gears and parts.
Old 02-10-2007 | 01:53 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Almost every gear vendor only has the 3.70 ratio. I dont know why other ratios arent more popular. I got mine from http://www.ring-pinion.com/
Old 02-10-2007 | 02:27 AM
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
What gears do you need? I've got a set of 3.27's sitting here in a box collecting dust. I've posted them on this board for $40.00 bucks before but had no takers.
Old 02-10-2007 | 03:01 PM
kbog54's Avatar
Car: 1983 Z-28
Engine: 305 CFI
well i was looking for a set of 4.10's which i know the guy from 9 bolt.com used to carry, seems i can't find anything higher that the 3.7 series..
Frozer!!!
01-19-2024 05:55 PM
hectre13
12-11-2023 09:14 AM
sailtexas186548
01-19-2016 01:21 PM
hectre13
08-26-2015 09:17 AM
1nastygta
08-08-2015 08:38 PM
