T56 clutch fork
Car: 1988 Firebird Formula
Engine: 5.2 tpi
Transmission: th700r4- TCI
Axle/Gears: fourth gen rear 3.42
T56 clutch fork
Does any body know the proper way to remove the clutch fork on a 93-97 t56. i had to rmove it to pull the tranny but it was a pain in the ***!
Car: 1989 Camaro RS
Engine: LT1 from '96 Corvette
Axle/Gears: 3.42 diff
The fork just pulls away from the pressure plate. You don't have to loosen it or anything, it literally just pulls down away from plate one you have the slave cylinder out of the way. There is a bolt that holds it to the tranny housing, but it is designed such that the fork will slide back and forth at that point.
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Re: T56 clutch fork
I have a related issue with my T56 swap. Is there any reason why it would be hard to push the clutch fork over the TOB once everything is installed? It doesn't seem to want to go on, yet when I had the tranny 1/2" away from the bellhousing it slid on easily. Thanks.
bigjay89gta
10-15-2015 08:04 AM
