what kind of flywheel do i need for t56
I am trying to get a 1993 Lt1 t56 bolted up to small block 400 and it is a 2 piece main and externally balanced, i know the lt1 is internally balanced and has a 1 piece main so where can i pick up the right flywheel for this application? thanks
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
Lots of people make them. I would call Mcleod Industries. They will have what you need.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
McLeod's info is at http://www.mcleodind.com/
monte87cortez
09-26-2015 08:10 PM
