clutch fluid reservoir location
Car: '89 Trans Am GTA
Engine: TPI350
Axle/Gears: BW 3.27s
I'm in the middle of an auto -> manual swap and I need to know how to mount the fluid reservoir and it's little bracket. Help and pics are greatly appreciated. thanks!
sorry I did search but couldn't come up with anything. thanks
1 Post
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
attaches to the outer master cylinder bolt if need pics let me know can get some in about 1/2 hour
Engine: TPI350
you're talking about the bolts that hold the master to the booster? ok, so looking at it from the front of the car it goes on the one that is to the right (or to the closest side of the car) correct?
lemme know, if I've got it wrong then yes please get me a pic otherwise no problem thanks
1 Post
yeah thats it if you need help on your wiring let me know done three conversions and can take pics if required
luke
luke
Engine: TPI350
thanks for the help and the offers for more. It's actually a T56 swap and I'm sure I'll find what I need but if I can't I won't hesitate to ask. Thanks man
Engine: TPI350
it's not hard as long as you have the bracket that the reservoir mounts to.
there's 2 bolts holding the master cylinder to the brake booster. from the front of the car looking towards the back of the car, you need to unbolt the right side nut holding the master on (you want the bracket to curve towards the closest side of the car). put the bracket in place and bolt it on. hope that helps.
Night rider327
09-02-2015 04:17 AM
