700r4
Car: 1986 Trans Am
Engine: Mild 10:1 355.
Axle/Gears: 9 bolt
I got a friend at Certified Trans. and he said they cant take much more then 280hp stock
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
I will comment that they come behind the 330 hp lt4, which is an electronic 700r4 known as a 4L60, they will go with different abuse per year desighn, the newer the better, my friend bought a 700r from tci built, he makes arround 400 hp and 400 lbs @ the flywheel, 3 years later its still good, it is all in how much you want to spend.
[CA] 700R4 trans & parts
6998poncho
09-25-2015 02:56 PM
