t5 with a 350hp crate motor
Car: 91 RS, t-topped, man trans.
Engine: 350cid 350Hp crate motor
Transmission: t5 with new stock clutch and parts
Axle/Gears: 3.08 stock -RS
hey folks.....i just put a 350 hp crate motor in my 91 t topped RS. the trans is solid along with a new clutch and a few tranny parts. proffesionally installed.
The delemma is I can only go approx 55MPH in 5th gear(T5) before it red lines while cruising. SO at 55mph my rpms are showing approx 5ooo to 6000 rpms.
i wanna puch this motor alittle bit faster
how can i fix this?
is this normal?
oh yeah this on on stock tires of course...235 55 16's
how can i fix this?
is this normal?
Received 1,837 Likes
Your tach is lying. Your motor is not turning 6000 RPM at 55 mph in 5th gear. You have 3.08 gears, if this was a 305 car originally: the motor is ACTUALLY turning about 1700 RPM under those conditions.
These tachs always do that. They fail by reading high.
Ignore it.
Ignore it.
hey pat....west jordan,UT here!
theshackle
09-17-2020 08:26 AM
theshackle
03-05-2017 06:37 PM
