Australian rear end?
Old 10-21-2006 | 12:11 PM
Chavez-1986's Avatar
I just figured out after talking to a parts guy at my local Pontiac dealership that the rear end in my 85 Trans Am is apparently Australian. The difference, as explained to me by this parts guy, is that its 7 3/4, versus the 7 5/8 that was stock in Canada and the US, apparently. However, that's all he told me. I know it can handle more power than the 7 5/8, but does anyone know off hand what exactly it can handle? I'm planning on putting a crate 350 into her once all the safety work is done, and I'd like to know if this rear end will be able to handle roughly 400hp.
Thanks.
Old 10-21-2006 | 12:49 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The "Australian" rear end is the 9 bolt Borg Warner. It was stock in the US and Canada.
Old 10-21-2006 | 01:32 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I didn't think it was stock in the '85 year though.
If the cover has 10 bolts it's the 7.5" or 7 5/8", if 9 bolts, 7 3/4". Only bad thing about the 9 bolt is the parts for it are harder to find.
Old 10-21-2006 | 04:29 PM
transam84's Avatar
the parts for the 9 bolt are def more money BUT on the good side the 9 bolt is supoose to be alot stronger than the 10 bolt. how much power it can handle before it blows I don't know, but I have a 9 bolt in my 84 T/A (not original of course) and in the car is my 383 motor and the rear end hasn't ever had a single problem. I have done the burnout contest at the Car Craft show here in July every year a few years in a row without a hitch. I wouldn't have any concerns in putting in a 400hp 350.
Old 10-21-2006 | 10:09 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It was available in the T/A in 1985.
Old 10-22-2006 | 02:27 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yep, optional in 85-89 in Trans Ams and 87-89 in Camaros. Also a very few 1990's that were using up the old stock of 9-bolts.
hectre13
12-11-2023 09:14 AM
Warlocksirix
09-03-2015 01:26 PM
hectre13
08-26-2015 09:17 AM
AkDrifted
08-17-2015 08:45 PM
Jlanz55
08-17-2015 08:15 AM
