Shaky at 65mph - driveshaft?
Car: 86 Firebird
My car shakes pretty badly at around 65mph and up. It seems to be worse when decelerating. Could this be my driveshaft, or is there something else to look for? I was thinking of installing a 98+ driveshaft. Is this a direct bolt in? Thanks in advance for your help!
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
You might want to raise the car up and check the U-joints. Your probably on the right track but it might be something like u-joint which are a not-so-costly fix. How long has it been doing it? does it cluck when changing to reverse to drive ect.? A quick call to inland empire will net you a killer driveline for not all that much and it comes with the U-joints already in
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I had a odd shake around 55 that I chased for a while. Turned out to be a lose door skin. Drivers side door skin near the mirror had come lose for about 3 inches. But was just enough to grab air over 50. Never noticed it till one day I had my arm hung out the window. I noticed if I kinda squeezed the door it stopped. Dab of silicone fixed it.
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
When my u-joints went out it shook the whole car. If the vibrations feel like they are coming from under the console and behind/below the seats then it is likely your driveshaft. Thats how the vibrations felt in my car at highway speeds.
IROCZDAVE (88-L98)
11-19-2015 07:03 AM
