High Stall Convertors
Car: 91 Camaro RS
Engine: 305 TBI
say... a 3000rpm stall converter
i never knew completely how these work
but correct me if im wrong... they only stall that high at WOT correct?
and then say it needs to idle at 900 rpm... it stalls at 1200rpm at part throttle?
am i correct.... even close??
1 Post
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Depends a cheap crappie one will not move the car until 2k-2.5k and spin up to 3k before getting under way well.
A nice tight 3k stall from someone like Precision Vigilante or Yank might cost more but makes up for it in droveability and efficiency.
they are known as tight converters and will still move the car out well without spinning to the moon on takeoff while driving.
There is a reason they are 600-700$ they drastically outperform the cheaper alternatives.
later
Jeremy
later
Jeremy
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Here's some torque converter information you should read first
http://www.hardtail.com/techtips/torqueconverters.html
http://www.hardtail.com/techtips/sel...converter.html
Car: 1983 G20 Chevy
Transmission: 4L60
Typically when you go up in stall speed, it is desireable to have a smaller converter body. It is a more efficient way of raising stall speed than changing the pitch on the pump in say a 12" converter. My Yank truck 2,800 is only 11" in diameter. For a car they are around 10".
Car: 91 Camaro RS
Engine: 305 TBI
that doesn't help me any... lol
if its a tight 3k stall converter
if i go WOT say around 3k it takes off and all hell breaks loose
but if i take off easy it'll stall nice and easy say at 2500 w/o chiprin tires or whiplash
Car: 1983 G20 Chevy
Transmission: 4L60
A tight 2,800 RPM converter will pull well at part throttle, all the way down at 1,200 rpm. I can pull away from a stop at 1,200 rpm with ease or hammer it go to 2,800 then all hell breaks loose.
Hotrodboba400
12-10-2019 07:07 PM
