View Poll Results: Which differential is better for all out traction?
Auburn posi clutch type.
41.67%
Eaton posi locker type.
58.33%
Voters: 12. You may not vote on this poll
Auburn or eaton differential.
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
I am looking into geting either an Eaton or an Auburn posi differential. I need everyones opinion on which is better.
Also, what GM vehicles came with these differentials already installed from the factory. I am looking to swap it in.
Come on guys somebody has to have experience in these two diffs. Or has anyone heard of a true track style diff that came in an S10? I have a pic but I don't know how to post it.
Take the poll!!
Take the poll!!
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
My eaton broke in less than 1 year taking the gears with it, and I don't have that much power.
I'd go Torsen T2R (this is more for auto-x/road racing though) or Auburn Pro.
Car: sold
eaton, i have had mine for 5 yrs now with no issues, and the can be rebuilt and alburn cant. there are alot of guys here that are running 500+ hp with no issues with the posi. eaton all the way
Car: 91 Formula WS6
Transmission: five speed
Car: 91 RS
Originally Posted by Julie Bergman
T2R for RR, AX, accept no substitutes! If you are drag racing then get whatever is popular with them, probably the eaton.
Car: 91 Formula WS6
Originally Posted by DM91RS
What was the Torsen HD version that SLP sold? Is that the T2R?
I didn't know there were so many options for posi units! I am looking mainly for staight line pure unadulterated traction. I do still want to make some turns without the tires complaining. What vehicles did all these rears come in? I see an Ebay auction for a true track style diff that came from an s10.
I can't really afford a new one right now.
Wow,
It looks like I should have added torsen diffs to the poll list.
Cross fire Z,
So what your saying is 93-96 posi 4th gens had Auburn diffs. 96-98 SS and WS6 cars got Torsens and all 98-02 posi cars got Torsens. What did the cars that were posi rear but not SS or WS6 get in 96-98? Also which of these different rears had the best posi unit in terms of traction and life? When you say some had Auburn diffs, were these the same ones that they sell to the public or did the General work out a deal for some lower quality higher quantity pieces?
What about the S series truck that share the same differentials as the F cars? Did any of them have better differentials? Maybe the Olds Bravada got something special cause it was an AWD SUV.
Any body have pictures of these different posi carriers or maybe an easy way to tell them apart??
Thanx guys!!
Cross fire Z,
Thanx guys!!
1 Post
Car: '94 Z28
Engine: LT1 350
Transmission: 4L60E/A4
Ok, let me clear this up, and read the years closely.
93-98 f-bodies that had posi (but not SS/WS6) got auburns, and from what I know it was a lower grade then the pro series. Yes, 98 got the auburn even though it was an LS1. It was the last year for the auburn. 96-98 SS/WS6 f-bodies got the torsens. 99-02 got torsens regardless if it was an SS/WS6 or not. If it had a posi and was 99-02 it was a zexel torsen.
As for the posi in trucks and blazers and such, I do not know. I have no idea what posi units they received.
A zexel: http://home.earthlink.net/~deton8r/i...exeltorsen.jpg
An auburn: http://home.wi.rr.com/montecarloss/I...urnProPosi.jpg
The two are easy to tell apart.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
S10s have 10bolt rears yea, but apparently most commonly got the dreaded gov-lock. Avoid it like the plaugue.
Not other vehicles would have a donor posi for you. So you're basically stuck searching 3rd and 4th gens. (Remember to match the spline count)
So Sonix, Your saying that the Eaton Gov-loc diff is a P.O.S? That's the one with the huge finger looking thing that drops into the teeth and kinda locks the two sides into place? It's failure prone or when it locks it's very apparent?
Did the monte carlo or the regals have the same rear size as ours?
Car: 1982 Trans-Am
Yea, the gov-lock, aka grenade lock is a POS. Do a search on it here and you'll see how much everyone seems to love them. It locks *after* you're two axles have different amounts of power, causing a grenade like reaction.
The visual description you gave kinda sounds like a normal posi though, the center finger (cross pin), and it's between the spider gears... I've actually never seen a gov-lock, only heard of it, so I don't know if that's what it looks like.
1 Post
Car: '94 Z28
Engine: LT1 350
Google rules!
http://www.astrosafari.com/images/re...Install006.jpg
Montes and Regals do not have torque arms, therefore, they do not have a bracket for it. The axle won't work. Also, I think they are 8.5". Well either way, they are not 7.5/7.625" axles.
UltRoadWarrior9
04-28-2020 10:39 PM
dbrochard
10-03-2015 12:43 PM
UltRoadWarrior9
09-02-2015 08:24 PM
