TCC lockup, not like the rest of the threads...
Car: 85' TA
Engine: 355 Carbed
Transmission: Built 700r4
I have a 700r4, it was built less then 9 months ago, and the company does not recall exactly if they installed a NC or NO switch, how can i test externally?
i have everything i need as far as data except one thing.
I located which ports are which, ABCD etc, and wrote down the Stripped Tan wire is Ground(terminal D), Purple wire is TCC Solenoid 12+, and Green wire, 4th gear pressure switch...
I dont know is the 4th gear pressure switch is +(pos) or -(neg).
I want to install a light, and if trhe light lights up all the time except 4th gear its a NO, and if only in 4th its a NC switch.
From there i can devise the best way to create my own TCC lockup system...
Car: 85' TA
Engine: 355 Carbed
thats what i'm thinking but i need full assurance, because, a diagram i have, shows it as +12v...
but whether i am reading the diagram correctly is my question, i dont want to burn up anything, so i am trying to be 100% sure before i screw with it all...
UltRoadWarrior9
04-28-2020 10:39 PM
LT1Formula
10-08-2015 08:34 PM
ramicio
09-28-2015 01:18 PM
