Whine at the top of 1st gear
Old 06-16-2006 | 12:32 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
I've recently noticed a whine at top of first gear. Not really much more to say, if the engine is above a certain RPM and still in 1st gear it will whine. Under normal driving with casual shifts, the whining starts about 1 second before the transmission shifts into second. It increases with engine speed, then goes away as soon as it shifts. If I increase speed until whining starts, then let off and HOLD the engine speed and car speed right at the point where the whining starts, the whining will hold steady until I either slow down, or the car shifts. Any ideas? Are my 700R4's days possibly numbered?
Old 06-17-2006 | 10:25 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Whining is bad.
Old 06-17-2006 | 12:00 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Is there anything else you can tell me? The whining is somewhat soft, for example if I am having an average volume conversation with the person next to me we both probably wouldnt notice it. Can it checked out by a dealership?
Old 06-17-2006 | 02:08 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
If you take it somewhere, they can listen and make a guess. Only way to know for sure is to disassemble and inspect. Disassembly is not practical. I saw a worn case bushing cause a whine in a unit. Pumps tend to whine when failing also. A pump, if need be, can be swapped without complete disassembly. Let a local pro hear it and let you know.
Old 06-17-2006 | 03:46 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
my TH350 does the exact same thing. Been doing it ever since I put it in the car (1.5 years ago). Its seen thousands of street miles and hundreds of 12-11 second passes. Never skips a beat.... if it aint broke I ain't fixing it.
Infested
05-23-2018 12:56 AM
Azrael91966669
25
06-20-2017 05:04 AM
InfinityShade
08-22-2015 09:00 PM
Dialed_In
08-20-2015 02:45 PM
